R55 Overheating.... going to mechanic tomorrow
Old Jan 23, 2020 | 10:09 PM
CHRISTIAN ALMANZA's Avatar
CHRISTIAN ALMANZA
It all started while I was running out of fuel this Wednesday. I was on fuel reserve. I had about 9miles left on gas. Suddenly the light “the engine is hot, drive slowly” turns on. I got worried. This happened in Boston, where you are constantly stopped due to high traffic.
I was on my way to the nearest gas station. When I got there, I filled the gas tank (I always use the most expensive gas available), and also put in some antifreeze since it was slightly under minimum level.
After this, the light has been coming on again. tends to turn on while stationary, or in traffic. Doesn’t come on while traveling in highway.
Old Jan 24, 2020 | 07:02 AM
Minidogger's Avatar
Minidogger
I bet the low fuel event was just a coincidence. Sounds like you have a cooling system problem.
Old Jan 24, 2020 | 08:10 AM
MiniToBe's Avatar
MiniToBe
check if the fan runs and/or water pump. was there pressure when you filled it with coolant? it could be a stuck thermostat.
Old Jan 27, 2020 | 10:46 AM
bugeye1031's Avatar
bugeye1031
Moderator
please give us an update!
Old Jan 29, 2020 | 05:38 AM
Might want to check these common areas for a leak. https://www.northamericanmotoring.co...8-no-heat.html
alanchicken
R61 :: Paceman Talk
Aug 11, 2015 01:14 PM
donjulio
Mar 2, 2011 07:07 PM
gggmini
Apr 16, 2010 03:53 PM
Gia
Feb 8, 2007 02:26 PM
Motor On
Mar 13, 2006 07:30 AM
