R55 Brake Question
Old Oct 9, 2019 | 03:30 PM
dkamp's Avatar
dkamp
Brake Question
I have an R55 2008 Clubman. I replaced my Front and Rear Brakes (and sensors). All works great, except the Emergency Brake.
When replacing the Rear Brakes I had to screw in the Caliper "a lot". My theory is that it has "NOT" self adjusted completely.
I read somewhere that the Emergency Brake also self adjusts. Currently I can pull it up about 9-10 clicks and it holds (some), just not the way it used to.
Should I do anything to hurry up the self adjusting? If so what?
Should I readjust for 3-4 clicks by tightening the Nut at the emergency brake?
Anyone know the e-Brake self adjustment stuff?
David
Old Oct 9, 2019 | 08:19 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I'd start by pulling the Ebrake about 30 times and see if they adjust out. I do it after every brake job
Old Oct 11, 2019 | 08:57 PM
dkamp's Avatar
dkamp
Thank you WayMotorWorks! That helped some and its getting tighter.
David
Old Oct 12, 2019 | 06:21 AM
cristo's Avatar
cristo
Alliance Member
Sometimes a few good firm
and HARD pushes on the brake
pedal helps advance the rear pistons.
devenh
Aug 21, 2013 05:29 PM
Dr Obnxs
Tires, Wheels, & Brakes
50
Jan 14, 2010 07:15 PM
MrCooperS
Jun 1, 2008 08:38 PM
dominicminicoopers
Aug 27, 2003 08:22 AM
Grinder
Mar 30, 2003 08:44 AM
