R55 Need help with my 2010 clubman!!
Old Jan 7, 2016 | 10:53 AM
jcjustice's Avatar
jcjustice
I did a clutch swap on my 2010 cooper clubman, over night I had the car apart and my blank**** dog chewed all the electrical connectors that were unplugged on the driver's side. I have fixed some of them, but I need the washer fluid tank level sensor plug, amber marker lamp plug that is in the fender, washer pump plug, fog light plug, and front turn signal plug. I was hoping someone on here may have a wrepped mini cooper or clubman. Both sides will be the same. Please help!!!!
P.S. My dog is still alive!!
Old Jan 7, 2016 | 01:30 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The washer level sensor plug is here (depending on damage you may need in conjunction with items here for #14), windshield pump here and socket here (#3 and #11 at that link; in conjunction with as well), and fog light socket here. Amber marker plug socket from this diagram here is here. The side one may have the same connector as the level sensor. If the opposite side maker is good then see if the level sensor plugs into it, if so you may need the same connector. Are you talking about the side turn signal? If you need help with any of this shoot me a PM and I can further assist you.
888.280.7799 | 6am - 5pm PST
Old Jan 8, 2016 | 07:25 PM
jcjustice's Avatar
jcjustice
Thanks for taking the time to look that up. I will be placing an order soon. 👍👍
Old Jan 8, 2016 | 07:39 PM
jcjustice's Avatar
jcjustice
I just tried to order them and the first link for the washer tank sensor does not let me place it in the cart to buy. The price says NLA?? What's that?
Old Jan 8, 2016 | 09:44 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've got several wrecks I'll look and see what I have for you.
I can cut off some extra wire if you want a chew toy for the dog later.
Old Jan 9, 2016 | 05:50 AM
jcjustice's Avatar
jcjustice
Ok thanks if you do have them I will buy them from you. I have paypal. I need the washer fluid pump plug, washer level sensor plug, and the plug for the corner light in the fender.
Old Jan 11, 2016 | 11:37 AM
PelicanParts.com
Vendor
Hm, that means that must have just gone NLA (no longer available). If you shoot me a PM with your contact info I can have our specialist reach out for you about possible options. Otherwise if Way doesn't have something, you can search www.car-part.com for those used components that are listed NLA as that website does a widespread search of used parts across the nation.
ALLMAGAutoParts
May 13, 2016 10:44 AM
MiniCS
Mar 8, 2016 10:47 PM
Emnotek
Jan 13, 2016 11:49 AM
Wisconsincooper10
Jan 4, 2016 02:51 AM
