R55 White, Sweet Smelling Smoke from Exhaust, HELP!!!
Old Mar 17, 2015 | 07:07 PM
MINIMAN1411's Avatar
MINIMAN1411
Yesterday I was in my 2008 Cooper S Clubman with 108k miles and after sitting in my driveway with the engine on for about 10 minutes waiting for someone, I noticed I was surrounded in white smoke. I panicked, shut off the car and ran out to see if it was coming from the engine bay and, but nada, I noticed it was coming out of the exhaust tips!
I'm a little upset currently, I just spent $900 replacing the Turbo Oil Line, Oil Filter Housing Gasket and Auxiliary Water Pump, which also included an Oil Change and Coolant Flush, and don't want to have to replace something else on this car. I did notice that the Coolant Reservoir is under the Min. line and was wondering if being low on coolant could be the problem because it was sweet smelling.
I tried starting the car again today to go to school and same thing, but the smoke was a little thicker and smelt a bit stronger, this is kind of worrying me. I also noticed what sounded like the death rattle, but it not lasted a minute and went away, it might have just been my nerves going haywire because my Chain Tensioner was replaced 10k miles ago, and it's been perfectly fine since I got the car at 100k miles.
Could this be anything to do with my driving style? The past week I kind of lost my mind after getting back my car from it being inoperable for 3 weeks and have been ******* it like crazy and keeping Sport mode on 24/7.
Any help is appreciated, thanks in advance!
Old Mar 18, 2015 | 05:59 AM
Pure Red's Avatar
Pure Red
Top off your coolant first. Check your oil level next. Coolant being burned out the exhaust will smell and look differently than oil smoke out of an engine. Oil tends to have a blue tint to the smoke, and coolant will smell sweeter than oil being burnt. Sounds like a coolant leak into the combustion area/block of the engine, but can't say without being there. let us know what you find.
Old Mar 18, 2015 | 06:42 AM
rckrzy1's Avatar
rckrzy1
sounds like a blown head gasket. Pull the plugs and look for a green or blue tint on them.
Old Mar 18, 2015 | 07:36 AM
Capt_bj's Avatar
Capt_bj
sweet is coolant
out the pipes is bad . . .
Old Mar 18, 2015 | 07:51 AM
Helix13mini's Avatar
Helix13mini
Do not drive or run your car. Don't bother topping off any fluids. Have the car towed to a qualified MINI mechanic. It could be that the shop boogered the oil filter housing installation and you're mixing coolant with oil and engine parts are getting hot. If you're lucky it's just a head gasket.
In any case, if you're burning coolant, the head will have to come off to inspect. Sorry, man.
Old Mar 20, 2015 | 03:18 PM
poor mini's Avatar
poor mini
Miniman1411, pull the dipstick and see if there is any foam/froth on the stick. It sounds like a head gasket is bad, with the car running, does the overflow bottle bubble, if so, your head gasket is going for sure, best to park and have towed. If you suck in enough water into the combustion chamber the engine can Hydrolock, resulting in bent rods, damaged pistons & bores ect........
surfblue
Oct 24, 2018 01:20 AM
MoganDavid
Mar 14, 2016 10:44 AM
theblackfalcon
Oct 11, 2015 09:49 AM
robbiedowns22
Aug 25, 2015 12:20 PM
theateist
Aug 22, 2015 06:58 AM
