I'm still debating about this issue with my S since the tires are all fairly new. With all the lower speed driving around the city, it doesn't bother me. But, once I finally get to higher speeds, wow, the noise level is SO noticeable....
I think if my commute or daily driving was more highway/freeway biased, I'd change them out much sooner.....
Tire noise can be indicative of tread cupping, a result of bad alignment. There's no fixing it once it has occurred. When you do make the jump to non run-flats (which you should do!), also get an alignment and check your suspension bushings.
It's not as common a problem with the 2nd gen cars, but you might want to replace worn control arm bushings with polyurethane bushings.
TRUE, but both of our MINI's have RFTs , and are noisier than any of our non-rft tires at higher speeds. The Michelin Snow Tires on my wife's CMS were instantly quieter driving on Lake Shore Drive the first time we took it out after I installed the winter rims and tire combo for the season.Originally Posted by Helix13mini
Tire noise can be indicative of tread cupping, a result of bad alignment. There's no fixing it once it has occurred. When you do make the jump to non run-flats (which you should do!), also get an alignment and check your suspension bushings.It's not as common a problem with the 2nd gen cars, but you might want to replace worn control arm bushings with polyurethane bushings.
At any rate, I need to put both cars on the alignment rack here at work to see what their baseline is compared to factory specs. Hopefully my little Clubman fits our drive-on rack safely......
close
- Join DateJan 2013
- LocationWadsworth, Ohio
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:2,551 Times in 2,258 Posts
Removal of the runflat does help the ride feel so much smoother. Also having the alignment checked and done at the same time.
For people up north having a dedicated Summer tire / wheel set and winter steerlies / tire set makes the ride much better and safer for each season.
I agree with what Helix has said. To that I will add if you don't rotate your tires they will get noisy. If you buy non-runflats & don't rotate you'll have noisy tires again. Make sure your MINI is in alignment & rotate those tires.
Quote:
Please relax everyone.... Chill....Originally Posted by ashchuckton
The Run Flat Conti's are new, less than 3k on them. They, and the Pirelli RFT's on my wifes CM S are noisy[ which are also fairly new] Not an unknown or surprise out of a Run Flat tire as compared to a Non-Run Flat in my experience with tires over the years.
I rotate my tires, perform my own alignments, on any vehicle I own.
I DO thank everyone for the advice and concern...
I still have the original runflats. I just couldn't bring myself to take perfectly good tires off to replace them with non-runflats, so I resolved to wear them out first. They are getting down on the tread now and I will get new runflat tires this summer.
This is the first car I have owned that has runflat tires, I haven't noticed any difference in sound or ride compared to my non-runflat cars.
