R55 Changing Xenon Bulb, Help?
Old Nov 1, 2013 | 07:30 AM
axelcrash's Avatar
axelcrash
Hi, My driver side low beam headlight is out. I keep getting the low beam malfunction warning. The bulb will occasionally flicker but does not fully turn on. The high beam still works just fine.
I have checked the fuses and that all wiring external to the headlight is tight and attached so no issues there.
Before purchasing the ballast/ignitor or other $$ parts. I wanted to check by swapping the working bulb with the non-working one. But.... I can't figure out how to remove the bulb. Seems silly to ask but I couldn't figure it out.
I have a 09 Clubman S. I opened the compartment on the back of the headlight assembly and get to the back of the bulb but there are two metal bars that are over the back of the bulb(?) preventing me from pulling it out. I have searched on the forums and can't find any step by step procedure. Help from the forum would be greatly appreciated.
Thanks.
Old Nov 1, 2013 | 07:54 AM
Here is video from Bentley Manuals , in the beginning they show a halogen headlight on the blue car but when the work on the xenon its a Xenon equipped MINI.
Here is the Bentley Manual which is great for how to and DIY's in case you need it for other thing on your MINI.
Bentley Service Manual : MINI Cooper ( R55, R56, R57 )
http://www.ecstuning.com/Search/SiteSearch/ES2216079/
Here is the D1S Xeneon bulb if you need to replace it.
http://www.ecstuning.com/Search/SiteSearch/63217217509/
And here are some aftermarket Ziza brand bulbs: D1S version.
http://www.ecstuning.com/Search/SiteSearch/Ziza_D1S_Gas_Discharge_Headlamp_Bulb/
Thanks and hope that helps. Good luck with the bulbs and be careful not to have power on and not to touch the bulb part.
Old Nov 1, 2013 | 08:07 AM
axelcrash's Avatar
axelcrash
Thanks!
Thanks! This was super helpful. I will get the bf to help with making sure all power is off! Will let you all know how it goes.
Old Nov 1, 2013 | 08:24 AM
Great,
Let me know how it goes. Have a great weekend.
Old Nov 3, 2013 | 08:58 PM
winL's Avatar
winL
I'll be ordering an R55 soon, how relevant is it if I pick up a copy of the Bentley service manual that only serves up to 2011??
Old Nov 4, 2013 | 05:07 AM
Its a great book to have, some items (if not most ) and part of the engine carry over from the 2011 models. Oil changes and general maintenance is the same. And congrats on the new R55 Clubman.
Old Nov 4, 2013 | 12:54 PM
winL's Avatar
winL
thanks! sorry to thread jack, but what are some things that might be different?
minimofo
Nov 16, 2016 05:56 AM
Rai1gun
R60/R61 Stock Problems/Issues
Jan 11, 2016 05:52 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
