R55 HELP- Barn doors will not pop open!!!
Old Sep 26, 2012 | 06:26 PM
  #26
schatzy62's Avatar
schatzy62
Thinking about this again the motor is built into yhe latch mechanisim for each of the barn doors latch assembly. So yes i beleive that you will need to replace the latch assembly.
Part number 51492754459 Lock for Split Door Right. Cost should be about $50 plus shipping if you order on line. I like PenskeParts myself. Great people there and they are actually a MINI dealer so you are getting genuine MINI parts
Old Sep 26, 2012 | 06:36 PM
  #27
hooops2001's Avatar
hooops2001
Wow really...that would be great. I will check that site now and THANK YOU again. How do you know so much? Wise man- ha,ha love your HC! By the way I'm originally from Chelmsford, MA... Go Patriots!
Old Sep 26, 2012 | 07:05 PM
  #28
hooops2001's Avatar
hooops2001
Great site...I just placed my order and hopefully that's all it was? Great price and still cheaper then my $200 deductible for my Maxcare warranty. Thank you!
Old Oct 21, 2012 | 09:27 AM
  #29
hooops2001's Avatar
hooops2001
Well...thank you again shatzy62 that Penske site was great and YES the issue was the latch. It seems like water has been getting into latch the past few years and causing for some rust to build up. I installed the new latch and it works Perrrrrfect.
Old Oct 21, 2012 | 05:25 PM
  #30
pmsummer's Avatar
pmsummer
I love happy endings!
Old Oct 21, 2012 | 05:41 PM
  #31
hooops2001's Avatar
hooops2001
Yes...appreciate your help also! I will post some pics of my new Sony double din head unit also happy camper here!
Old Dec 12, 2012 | 03:28 PM
  #32
gcaspelich's Avatar
gcaspelich
Replaced Latch today
We had heavy rains last night and that finally did the latch that locks the left barn door. Took out the rubber weatherstrip part way, remove the plastic bottom trim piece held by 4 plastic push clips. Next removed the electrical connector and then took a T25 torx bit and removed the two silver screws. I suggest holding the mechanism while removing the screws. Called Braman Mini WPB, FL and they had the part 51-24-7-167-498 for $57. Pelican Parts sells the part for $45 plus shipping but figured I would bite the bullet and go to the dealer. Installed new part at home and total time took about 15 minutes for the replacement.
Old Aug 5, 2014 | 07:21 AM
  #33
CooperClubman's Avatar
CooperClubman
How did you access the Left Rear Barn Door Lock
I need to replace my LEFT (Drivers Side) rear barn door lock. How do I get to it to unlock it without breaking trim pieces? Would really appreciate some help on this issue.
Thank You,
Bruce Condit
Old Sep 4, 2014 | 06:33 PM
  #34
utell's Avatar
utell
Originally Posted by hooops2001
Thank you again for the pics...really helped and YES I was able to reach the latch by pulling the rubber piece and sticking my flat head screw driver. I will post pics tomorrow and NOW for the not so great news. It seems like the latch has lost it's smoothness/click and won't release. When I press the key fob too unlock the barn door I hear the motor but it just doesn't release the latch. I'm assuming I will need a new latch mechanism. Would I be able to attach video on here? For you guys to see...maybe will help someone else in the future.
Hoops, I have the same problem. How did you reach the latch? I can not seem to do it.
Old Sep 5, 2014 | 10:28 AM
  #35
Blind Dog Daddy
Originally Posted by CA94960
That is how my Clubman works, except the passenger barn door only opens a few inches and not all the way.
Early Clubbies only opened the passenger door few inches, later versions swing completly open as the drivers side doors do.
That function is built into the gas struts. I had to replace one on an early version and got a new version strut which allowed fully open functions. Seemed the part had been superceded to new version.
Old Sep 5, 2014 | 10:38 AM
  #36
Blind Dog Daddy
I have a spare rear trim threshold cover if anyone needs it.
Old Sep 6, 2014 | 11:22 AM
  #37
utell's Avatar
utell
I still help on opening my 2009 Clubman Barn Doors. I can not figure out how to open them.
Old Sep 20, 2014 | 06:21 PM
  #38
Offroadbozo's Avatar
Offroadbozo
Mine pop open too!
Originally Posted by miffy
I had the opposite issue with mine, they kept popping open when driving. I had the door mechanism changed as this was a fault recognised by mini under warranty..there have been issues in the uk with the barn doors..
This just started happening on my 2010 Clubman also! It happens randomly whether driving or parked. Recently, the entire interior panel of the passenger's side door fell off as said door popped open while I was parked! I contacted the local dealer and they claim to have never heard of this problem occurring. I don't know where to turn...
Old Oct 23, 2014 | 12:03 PM
  #39
Here is a link to the barn door lock and how to access them, if you do them in pairs it will help having the out upper fail, then the other.
https://www.northamericanmotoring.co...arn-doors.html
Old Jan 24, 2020 | 01:10 PM
  #40
bugeye1031's Avatar
bugeye1031
Moderator
Manual Barn Door Release
Decided to add a manual release of the passenger side barn door while I had the trim off. I put together a quick, simple, and dirty solution using a small wire tie, fishing line, and a plastic straw. The mechanism has a manual release built in that looks to use a wire and very small lead "barrel"...something like the end of a brake cable on a bicycle, only smaller. The mechanism releases the latch when pulled to the rear of the car/rear of the mechanism. I attached the wire tie to the manual release, tied the fishing line to the wire tie, looped the fishing line under the mechanism and out through trim. Not very elegant, but I tested it a few times and it works like a charm.
The release mechanism is the small "slot" above and to the right of my pointing finger.
View from above. The wire tie attached to the release mechanism, with the orange fishing line going to the plastic straw. I taped the straw to the body of the latch mechanism, with the fishing line coming out of the bottom. If the mechanism fails, I can reach in and pull the fishing line.
Old Jul 14, 2022 | 08:18 PM
  #41
Clockwork's Avatar
Clockwork
Right side rear door opened from inaide
So I'm in same boat as you and my passenger (right side) barn door will not unlock. I can hear a very slight low sound when I press unlock button on key fob. Black button on actual door handle seems dead. No activity at all when pressed (neat to know about the gas shock only doing the 1.5" opening during pre-LCI then after LCI it opens fully... I may upgrade to new shock, but I also sorta enjoy the fact that the door only opens a little bit.
Waszak
Oct 21, 2017 05:55 PM
xpunisherx
Nov 27, 2015 03:32 PM
Filmy
Sep 7, 2015 08:27 PM
spackletooms
Sep 1, 2015 10:12 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
