R55 How do I know the LSD is installed?
Old Aug 30, 2009 | 07:10 PM
mbu's Avatar
mbu
Hopefully I'll be picking up my Clubman next week and one of the options I ordered is a Limited Slip Differential (LSD). How will I know it is installed?
Old Aug 31, 2009 | 07:08 AM
freez3's Avatar
freez3
From: United States of America, Ohio, Stark County, Uniontown
I guess if it's listed on the window sticker you got it.
Other than that... I don't know.
Old Aug 31, 2009 | 10:36 AM
Alphawave
Guest
Posts: n/a
Armed with a torque wrench, jack up on side, leaving the other planted firmly on pavement (secure MINI with blocks, as you leave it in neutral and NO HANDBRAKE!). Try to turn the lifted wheel using the torque wrench, and note at which setting the 'click' actually begins to move the wheel..this is the torque required to overcome the clutch (typically less than 30ft/lbs but the manual should indicate the exact torque required). If both wheels jacked in the air, both should spin the same direction.
Old Aug 31, 2009 | 10:44 AM
mbu's Avatar
mbu
Thanks Alphawave!
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
