R55 Fuel Economy Mods
If you can some how figure out how to drive in a vacuum, then you can really increase your mileage. Also, for $40,000, there's a company in South Carolina that will put an electric motor in your car. I've got some other ideas that involve tying ropes to objects in outer space, but I won't discuss it because I wouldn't want you all to think I'm crazy.
I agree - but does anyone still downshift through the gears to stop? I generally predict momentum to the upcoming stop, make sure I have enough speed to arrive at a normal pace, push the clutch in once and coast my way there barely needing to brake at the end. Brake pads are cheap and I can't remember not getting at least 70k out of pads on manual cars. Huge fuel saver too. Of course this doesn't include a fun drive through a twisty canyon.
Plus coasting in neutral is very dangerous...just imagine if someone was flying behind you not even thinking about using their brakes....much easier to get back on the gas than gaving to select a gear and get on the gas
What I do is usually just downshift when gear and ride it out to a little over 1000 rpm (which is close to 10-15mph in most gears), then clutch in and put into neutral
One quick addition about the Cooper vs. S models. The Cooper Clubman has taller gearing, meaning it will rev lower in all gears at the same speed than the Clubman S.
My MA told me that regular gas (87 octane) for a non-S is fine. I didn't think that it would be based on the owners manual but she said that is what her customers use......either 87 or 89. I was surprised.
Any feedback regarding fuel for a non-S? I don't want to mess up my engine. I'm filling it up in the morning for a road trip.
Sailorboy, I believe you meant mpg increased. Nonetheless, if you are wishing to increase your gas mileage, I suggest two things.
First, know your gas mileage with your current driving style. I recommend a ScanGaugeII. Although $170 is a lot to tell you something you can easily compute on average, it tells you instantaneous mpg as well as every other statistic available through an OBDII port.
Second, while hypermiling is somewhat extreme, watch this video and take away a few things.
http://video.google.com/videoplay?do...NZzA4ALN662SDA
Woah, wait a minute. I take issue with this statement. There is no difference in detergent levels between 87 and 93 octane, if purchased from the same brand. Mobil 87 (for example) is not "dirtier" than Mobil 93. The only difference is octane. Minis control detonation by retarding timing (and reducing boost on turbos) so lower octane fuel will force the engine to limit itself to avoid detonation. But that is not going to increase the amount of deposits inside the engine. Running generic gas like something from Costco or Racetrack might allow the engine to build up carbon since there are no additives.
It is the additives, not the octane rating, that keeps engines clean.
Regards,
Terry
Regards,
Terry
This is not entirely true.....Chevron does have specific additive packages for the different octanes. I don't know about the other brands tho.
That's what I do! My Clubman sits in my garage while I commute 15 miles each way to work. A tank of gas lasts me many weeks. It's been one month since I filled up my Clubman and over four months since I've filled my truck (which still has a 1/2 tank).
patsum
26
May 29, 2021 06:29 PM
Alanberto
Sep 22, 2015 07:30 AM
