R55 Pictures of Clubman with REAR Fog Light
To clarify.... Whether you get the rear foglight option or not, there is only one reverse light and it is on the right-hand side. The taillights in the picture above is the way that every Clubman will look. It's just a matter of whether there is an actual rear foglight bulb in that space with a switch on the dash.
A car in Madrid, Spain. Left hand drive, left hand fog.
http://www.mini2.com/forum/mini-club...clubman-s.html
A car in the UK, Right hand drive, Right hand fog.
http://www.mini2.com/forum/mini-club...y-clubman.html
Actually, the single rear FOG light has been common in Europe for years, but there usually were two reverse lamps (at least when I was there in the 80's).
Beer is cheaper than Coke.
The Mayo on French Fries is great (and nothing like US mayo). In Belgium there are usually many toppings to pick from, including hot sauce.
THEY have football, in which FEET are mostly involved. In US football, the ball is only occassionally kicked. (Not that I don't like US football...).
Beer is cellar temp, not room temp. and it has much more than 2% alcohol.
Yeah, there is that hairy pit thing, but it was about 50/50 when I was there. They also aren't so hung up about nudity (which could be good or bad, depending on the hairy pit thing).
When you go to a restaurant there, their main objective is not to get rid of you as soon as you come in, so they can turn-over the table 40 times a night.
I'm glad my Mini has 2 rear fog lights, in case I ever have to use them.
Yes, I believe there is a single rear fog light on U.S. spec cars. If there were fog lights on both sides it would appear as though you were pressing on your brake pedal while driving when your fog light is on.
I believe it has something to do with the nature of the one sided fog being on the inside near the center stripe (drivers side).... It's a common practice to have a single fog light and to place it on the drivers side towards the center line of the road.
Yup....shouldn't be too hard.
And who knows....there's a possibility that you wouldn't even have to string the wire over to the other light. There's a good chance that there is a spot on the left hand side harness for the UK reverse lights that just isnt being used right now.....if that's true, just plugging the new UK taillight in would switch it to a reverse lamp.
I think the regular Clubman has the fog lights as noted in the above picture, though. The S Clubman should have them in the grill.
In the R53, the rear fog light (On 2005+ cars) was mounted down low on the center of the rear bumper. In the R56 Cooper, the rear fog light is also in the center of the back bumper but in the R56 S it has 2 rear fog lights. I have the rear fog light in both my MINIs and I live in Miami. We very rarely get fog downhere (Yesterday morning was one of those days) but it is a safety item. Tailgaiters quickly backoff when you suddenly turn on the fog light on them. Also it looks better, specially on the R53, where a ugly black plastic cap is put in place when the rear fog option was not ordered. I also like having a FULL toggle switch and quite frankly the car looks great. At $100 for a factory installed option, the rear fog light is a bargain. If you decide to do it at the dealer, it will run you $400-$500+ easily for parts and labor. Yes the Clubman is akward in its "anti-simetry" design approach but I like it.
If everyone would just take a look at the 2007 MINI Cooper S, then you'd have an answer to the fog light question. I was looking through the 2007 Cooper S model and they showed the rear fog lights in the grill. The regular Cooper model has one single center fog light, while the S model has two fog lights located within the grill. One on the left and one on the right. It wouldn't make sense to call them foglights if it is located to where the backup lights are located. They need to be lower and on par with the front fog lights. So please take a look at the Regular MINI Cooper brochure, since the Clubman brochure is 1/3 the size of the Regular MINI brochure.
What? No. The rear fogs don't do the same job as the front fogs. The front fogs are meant to light up the road close to the car so that you can retain some visibility in fog. In order to achieve this, they need to be low to the ground to light up the area closest to the car and off to the sides.
The problem with your comparison is that the rear's have nothing to do with lighting up the road or providing the driver of the clubman any visibility. The sole purpose of the rear fogs is to provide a bright light so that other cars behind you can see where your car is even when you're not braking. If anything....it's better to have them higher up, closer to eye level of those in the cars behind you so that they definitely see your vehicle.
It is a good thing to have, even in heavy rain events where visibility is diminished.
In the UK, the Clubman rear fog is on the opposite side of ours
It was clearly not an afterthought but well integrated into the design of the R55.
Down here in South Florida on one of those lightning storm rainy days where you can hardly see 3 feet in front of you and everyone is still doing 65 on I95- that rear fog light is a great thing to have.
Well woth the $100.00
I think that price comes from the fact that the dealer will probably order a new full toggle panel and will also charge you for the time it takes to install that as well as the time for programming the computer.
I could have used one this morning. A girl in a mid-90s Honda Accord was very impatient as I passing someone while doing 77 MPH. Apparently, 12 MPH over the legal limit wasn't fast enough for her. Flipping on a fog light would have spooked her a bit, considering how close she was to my bumper.
A couple of years ago, coming back from Naples, we had one of the worst rain downpours in memory. We were driving back to Miami on I-75 on the alligator alley. That rear fog light in my R53 really came in handy. One other time we encountered really bad fog was in the Cherohala Skyway at 5,000FT elevation... The scariest ****! Once again the rear fog came to the rescue...we could not see beyond the leading edge of the bonnet. Talk about a full instrument approach!
