R52 Cabrio Tailgate adjustment?
Old Mar 15, 2007 | 05:14 PM
BlimeyCabrio's Avatar
BlimeyCabrio
I noticed earlier this week that my cabin light was coming on while driving - then noticed that the bonnet/boot warning light was coming on also. Turns out that the left side of my boot isn't closing quite flush - as a result, it isn't depressing the plunger switch far enough - so on bumps, etc. is thinks it's open...
Anyone have an experience or knowledge of adjusting the latch to correct this problem? Dealer is 2 hours away - so I'd rather not go there just for this...
Old Mar 15, 2007 | 05:38 PM
homerwest's Avatar
homerwest
I've heard a rumor about this, and I'm having the same problem occasionally. I figure I can wait until the 10k oil change, as it is very intermittent. You might try a search in one of the problem threads. I think I read about a service bulletin.
Old Mar 16, 2007 | 07:50 AM
MY4thMINI's Avatar
MY4thMINI
sorry
that's news to me too
my PT Cruiser convertible boot would pop if i hit a bump to hard
Old Mar 16, 2007 | 07:53 AM
davavd's Avatar
davavd
Originally Posted by BlimeyCabrio
..the left side of my boot isn't closing quite flush - as a result, it isn't depressing the plunger switch far enough - so on bumps, etc. is thinks it's open...
I used to have this problem all the time before my accident. Since I got my car back, it hasn't happened once
Old Mar 16, 2007 | 08:06 AM
goaljnky's Avatar
goaljnky
It was a known problem with the 'verts. You dealer should be able to adjusted fairly easy.
Old Mar 16, 2007 | 10:05 AM
BlimeyCabrio
Just trying to avoid a special trip to the dealer...
I put a little piece of foam tape on the tailgate where the switch strikes it - that solved the intermittant lighting issue for now. But in my case, the left side of the tailgate is probably 2-3 mm from being flush - right side is nice and flush. So if I could adjust the latch, that should do it. I'll tear into it this weekend...
Old Mar 16, 2007 | 12:26 PM
BartMack's Avatar
BartMack
yep, same here- they adjusted mine, no more issues.
Old Mar 16, 2007 | 09:51 PM
brownflyer's Avatar
brownflyer
The dealers know about this issue but it's not recall priority. I was having the exact same problem with mine. When I took it for service, I told them about it and they replaced the switch with one with a longer plunger.
I also tried adjusting the boot but that didn't solve the issue.
Old Mar 17, 2007 | 09:20 AM
MY4thMINI's Avatar
MY4thMINI
so is your baby back to normal
Old Apr 23, 2007 | 12:01 PM
davavd's Avatar
davavd
Hmm, missed this somehow, but yes.
Keet
Suspension
Aug 30, 2016 03:46 PM
vetsvette
Oct 11, 2015 06:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
