R52 Clutch Issues
Old Feb 15, 2020 | 06:21 PM
Ray R. Canales's Avatar
Ray R. Canales
Clutch Issues
Ok guys I need some help I have exhausted my limited knowledge on my car. car wouldnt go into gear with clutch depressed while car is on but it would with car off, changed the transmission fluid it was dark no metal shards that didnt do the trick , changed the slave cylinder today tried to bleed it after quite a few attempts there was still air in the system removed it from the car to compress it and saw the shaft was bent, any ideas on what could be wrong? 6 speed manual
I am baffled 100%
Old Feb 15, 2020 | 06:34 PM
Canyon_Mini's Avatar
Canyon_Mini
Most likely a failed throw out bearing or pressure plate.
Old Feb 15, 2020 | 07:27 PM
Ray R. Canales
that sounds like is gonna be some work like drop the transmission , if you know of a link where I can see a youtube video on how to do that job?
thank you
Old Feb 15, 2020 | 08:56 PM
Fly'n Brick's Avatar
Fly'n Brick
These may be of help to you to at least get to the clutch/TO bearing assembly. The 1st link is part 1 of 2 for a justa, the second is part 2 of 2 for the S, the 3rd is a time lapse video of gear box replacement and the 4th is a written step by step. That should be enough for you to get in to the box and do what needs done. Good luck and be sure to let us know how it went.
And always remember: Topless motoring IS motoring at its best.
https://www.pelicanparts.com/techart...eplacement.htm
Old Feb 16, 2020 | 01:23 PM
user 7389739's Avatar
user 7389739
He also did a quick video comparing the OEM dual mass to the Valeo single mass clutch kit, and why he favored the latter over the former:
tjsadler
Sep 13, 2019 01:55 PM
Tableleg
Jan 7, 2019 04:43 PM
GordoR53-702
Apr 26, 2018 10:27 PM
Prinler
Aug 17, 2017 10:03 PM
scoopy
Jun 28, 2012 09:48 PM
