R52 New to Minis Need Some Help
Old Aug 10, 2015 | 10:53 PM
mdorn98's Avatar
mdorn98
Hi Guys, I recently decided Id like to purchase a mini cooper s convertible. I found one that fits the bill and was hoping someone could point out to me the common problems of this model and if its a fair deal or not. I go to look at the car tomorrow so any advice would be greatly appreciated. Thanks
Year:2006
Color:Grey
Miles:75,000
Asking Price:8,650
Trans:Auto
I will also include links to pics of the vehicle for reference
Pics:
http://s34.photobucket.com/user/mdor...?sort=3&page=1
Old Aug 11, 2015 | 04:09 AM
JABowders's Avatar
JABowders
Veteran: Army
Personally I would avoid the auto transmission (with Paddle Shifter?)... BUT if you get it, the NEW line of thinking is transmission filter and fluid change between 100 and 120K miles.
It is a very well equipped car, and I do like the two tone cockpit.
What sort of history does the car have?
And do you have an independent tech that can look at it for possible problems?
The most common are, front strut mount bushings, lower control arm bushings, Motor mounts, and with the R52, the rear belt line trim, each side is about $145.00.
Best of luck!
Motor on!
Old Aug 11, 2015 | 06:17 AM
Helix13mini's Avatar
Helix13mini
I'd second the Auto trans. Not that they're time bombs, I just trust the manual trans more. The best thing you can do is take it to a qualified shop and have a PPI done. It'll be the best $100 you'll ever spend. There are a number of things that wear out on R52s which will need replacing, so having a good idea of the scope of work will help you negotiate.
Old Aug 11, 2015 | 06:54 AM
The convertible top, make sure it functions and works. And if the front cables have been replaced for the sunroof function. 54347174761
Sunroof Mechanism / Convertible Top Cable Set
http://www.ecstuning.com/Search/SiteSearch/54347174761/
Also check those other items mentioned by JABowers.
The rear trim set can fall apart: We have the full kits with hardware or the just the trim sets themselves. 51137123438 KT
http://www.ecstuning.com/News/MINI_R52_Trunk_Molding_Convertible_Cooper_S_JCW_Tr im_Cracked_Damanged_Hardware_Screws_2005_2006_2007 _2008/
The interior and options look nice. I would have it inspected and a good going through , top to bottom.
Old Aug 11, 2015 | 06:55 AM
Fly'n Brick's Avatar
Fly'n Brick
Other items to pay attention to:
Canvas care - the two best products are 303 and Ragg Topp.
Serpentine belt about every 30 - 35K
Power steering hoses.
The little button on the upper left side of the boot where the door makes contact. May need a little slider pad. The switch piston was never long enough.
Use only dry lube on the top scissor joints.
Install front strut tower plates to protect them from mushrooming. (nuts torque to 25#)
The thermostat housing should have already been replaced a couple of time so you shouldn't have to worry about it.
Use ONLY top tier 91 or better octane or risk knock sensor failure. http://www.toptiergas.com/retailers/
You might enjoy a pair of wool seat covers for summer and winter top down parking. Seats get really hot/cold. We like these
http://www.sheepskinstuff.com/Vest_S...vest-under.htm
Another add on is a windshield prism so you can see overhead stop lights from - http://www.lightinsight.com/ or Way Motor Works.
Most of all, remember that topless motoring is motoring at it's best.
Old Aug 11, 2015 | 08:49 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Best of luck!
Motor on!
+1 Great advise. Definitely have an indy MINI specialist take a look at it if you do decide to purchase it.
888.280.7799 | 6am - 5pm PST
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
