R52 need a part number for 2005 R52
Old Dec 4, 2013 | 07:32 AM
Rodjockey's Avatar
Rodjockey
I need a new seal for the rear driver side window. Any help would be appreciated
Old Dec 4, 2013 | 07:39 AM
ZippyNH's Avatar
ZippyNH
The diagrams and skametics are at realoem.com
Just put in your production date or Vin....and go to the part of the car by system..
Old Dec 4, 2013 | 08:22 AM
Got it for you.
Looks like you need the outer weatherstripping below the side rear window.
Rear Weatherstrip Trim - Left ( driver side ) Part # 51367072931
http://www.ecstuning.com/Search/SiteSearch/51367072931/
Here is the one for the passenger side if you need it.
Rear Weatherstrip Trim - Right ( passnger side ) part # 51367072932
http://www.ecstuning.com/Search/SiteSearch/51367072932/
They clip onto the body at the top of the panel. #14
Old Dec 4, 2013 | 08:28 AM
Rodjockey's Avatar
Rodjockey
Thanks for your help
Old Dec 4, 2013 | 08:35 AM
You are welcome, Not a problem, check the rear strip that goes all the way around the back, it matches those pieces, for deterioration since your there. Its the same designed strip that goes around the back. Easy to unscrew and install.
We have them in kits with and without the hardware ( screws and such ). The screws can really take a beating from salt and such and hard to put back in and tighten. Would be good to check the condition of yours.
Convertible Top Rear Trunk Molding Kit 51137123438KT
http://www.ecstuning.com/Search/SiteSearch/51137123438KT/
With install hardware:
Without install hardware:
Thanks again.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
absolutcamper
Aug 24, 2015 12:27 PM
xraycat
Aug 15, 2015 06:43 AM
Cal45fan
Aug 11, 2015 03:50 PM
