Backup sensor
Subscribe
May 4, 2010 | 08:00 AM
The backup sensor in my 07 Cabrio keeps blowing fuses. Anyone else have this problem? Thanks!
Reply 0
May 4, 2010 | 09:50 AM
The fuse F41 for the backup sensor is also used for the power steering fan, which is known to fail frequently. You should get it checked out. It is potentially a safety hazard.
Reply 0
May 4, 2010 | 11:18 AM
I had the same issue with my 07, and as the other person said, have the power steering fan checked. The power steering fan was bad in my Mini.
Reply 0
May 6, 2010 | 03:58 PM
Power steering fan?
I assume the power steering fan cools the power steer pump (which I understand to be electric). Is that on all the time? I assume that if it fails you can cook your power steering pump which I understand is electric.
The reason I ask is that I got my car back from the dealer and the back up beeper was not working. Since my bike rack makes the back up beeper whenever I shift into reverse, I wasn't too concerned when it didn't work. It was a "feature" that I wish had an on/off switch.
I should check the fuse (I have had the car for almost 3 years and have not yet needed to open the fuse box).
Reply 0
May 7, 2010 | 11:58 AM
I'm on my third fan for my cabrio. Weak link in the mini's armor....
Reply 0
May 9, 2010 | 09:28 PM
Yup. Power steering fan. I've had a couple too.
Reply 0
May 13, 2010 | 11:02 AM
That was the problem...you would have thought the dealer would have checked it out without my telling them-thanks guys!
Reply 0
May 14, 2010 | 11:19 AM
Fuse 41?
I opened both the fuse box under the hood and the fuse box on drives side kick panel. The fuse numbers don't go up to 41. Any suggestions?
Reply 0
May 14, 2010 | 12:22 PM
What fuse number does yours go up to? This was posted in another thread: https://www.northamericanmotoring.co...nd-wiring.html
Reply 0
May 26, 2010 | 02:49 PM
fuse 39
It looks like my "fuse 41" is fuse 39. Not blown which means my backup warning is due to some other problem. Off to the dealer...
Reply 0
Subscribe
