R50/53 Hidden DSC mode?
Old Nov 14, 2009 | 02:43 PM
  #26
Soni's Avatar
Soni
Originally Posted by Soni
I was at the track yesterday, when I hit 170km (105mph), the traction light (DSC) lite up and stand on. I tried to push the button to activate it back, nothing, the light still stay on. Until I shut off the car and restart it, then the light went off. But once I go over 170km (105mph) again, it light lite up again. Anyone know what is that? I recently install a Quaife LSD and Stage 4 clutch with flywheel. Anyting to do with thoese 2 mods?
anyone can chime in?
Old Mar 5, 2010 | 11:57 AM
  #27
rallymaniac's Avatar
rallymaniac
Originally Posted by blalor
I don't think holding it down does anything but turn the light back off; it probably thinks something fell against the switch, or it's stuck. :-)
I'm with you on this. I tried it multiple times before on my 06 cooper and nothing happens. You basically can ony disable or enable DSC with the switch.
The question I have is how to disable everything (All systems: ABS, DSC, and stability controll) without killing the speedo and odometer ?
I've tried all fuse combination (there is 4 or 5 to play with that have ABS, DSC functions) and it doesn't work.
Next on my list is to try and unplug the ABS unit by acutally pulling the harness that connects to the ABS pump.
Old Mar 5, 2010 | 02:44 PM
  #28
ZippyNH's Avatar
ZippyNH
Sounds like a bit off topic....just sounds like a fault....perhaps a bad sensor (wheel speed most likely).
Old Mar 5, 2010 | 02:48 PM
  #29
ZippyNH's Avatar
ZippyNH
Talk about bringing an old topic back.....Try a post with what you want to do in the title or better yet a search..try posting a new question with the relevant info in the topic...an mostly off topic post like is is unlikely to get you much help!
Old Mar 5, 2010 | 03:18 PM
  #30
Dr Obnxs's Avatar
Dr Obnxs
Just discconect one of the wheel speed sensors
and the system doesn't know what to do. I think speed is taken off rear passenger side, but I could be wrong on that one.
Matt
Old Dec 30, 2010 | 04:53 PM
  #31
liquid wrench's Avatar
liquid wrench
the bowles of the 04 mcs computer
Ok finally maybe I can find someone here to help me out.
I was in the computer via the trip reset button trying to turn the 10 mile per hour door locks off. I was in LEsE mode and inadvertantly hit the DSC switch and now I have the Mini in a track mode? the air bag light is lit the tire preasure monitor is lit and the triangle with the counterclockwise arrow are lit. is that the the dsc or the traction control?
I had the car to the mini shop and they didn;t really know what was wrong but they said for a couple a K they could fix it.
Any help would be greatly appreciated Motor ON!!!!!
Old Jan 22, 2011 | 08:57 PM
  #32
billie_morini's Avatar
billie_morini
this is one of the most interesting discussions about DSC we've had on this forum. Thanks to all that shared.
Old Jan 23, 2011 | 12:01 AM
  #33
Cadenza's Avatar
Cadenza
DSC ausmachen?!? Das ist verboten!!!
wildwestrider
11
Jan 29, 2016 05:06 PM
potterstein
Oct 2, 2015 09:30 AM
Samhillrocks
Sep 29, 2015 12:55 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
kevinlhr310
Sep 27, 2015 02:31 PM
