R50/53 Highest mileage MINI so far?
Old Aug 1, 2006 | 11:08 PM
  #26
goin440's Avatar
goin440
Originally Posted by caminifan
Do you have a CVT by any chance? If so, at what mileage point did it fail?
my 5spd failed at 75k- out of warranty, dealer wanted $4600 to fix. I called MINIUSA, and ended up paying out only about $900 in labor.
Old Aug 9, 2006 | 11:19 PM
  #27
DrkSlvrS's Avatar
DrkSlvrS
I'm close to 119k - put 26k on my first year.
Daily driver (Duh!) and 100 mile round trip to work put the miles on fast (plus the drive to AMVIV every year).
Just thought I'd put out the word to 115k and above drivers - my S/C just failed. No oil in the gear housing for the water pump, at the back of the S/C.
So all you 115+ drivers... make sure you have someone pull the S/C and put oil in that baby.
T
Old Aug 10, 2006 | 06:00 AM
  #28
dbwilldo's Avatar
dbwilldo
Coordinator :: Southern California MINI Maniacs
so did you just have to oil it or replace the SC altogether?
I have heard that the supercharger is only good to about 150K miles. I guess that was way off. But it was because of the oil.
Old Aug 11, 2006 | 02:20 PM
  #29
CDMINI's Avatar
CDMINI
"I'm about to hit 1,600 Miles, do I get a prize? "
YES, you get to learn how to do your first oil change. I did it that way.
Old Aug 11, 2006 | 03:39 PM
  #30
MINIBee's Avatar
MINIBee
I picked up my MCC on 3/29 and I'm already at 8,900 miles. My commute is 300 a week. So I guess I'm on my way to some pretty high mileage. At least I'm loving every mile!
Old Aug 12, 2006 | 08:06 PM
  #31
DrkSlvrS's Avatar
DrkSlvrS
Without lubricant the gears eat each other up (and they don't sell just the gears).
After my mechanic searched around for a supercharger I found one through NAM - Keith, in TX, had one for sale and I bought it yesterday. I should have it on Monday - in the car on Tuesday - back home in my garage on Wednesday (I hope!).
Looks like I was off on my warning ... the supercharge is only good for approximately 100k.
Forewarned is forearmed!!
T
Old Aug 12, 2006 | 09:41 PM
  #32
flannelhippie's Avatar
flannelhippie
Im pushin 56k.
I dont mean to toot my own horn...... but toot, toot.
Old Aug 23, 2006 | 02:55 PM
  #33
HighSchoolzMINI's Avatar
HighSchoolzMINI
Atleast its safe to know that some of these aftermarket parts will last so long
and i only just 7000, itll be 8000 when i get back to ny
Old Aug 24, 2006 | 01:01 AM
  #34
dix's Avatar
dix
Originally Posted by mdsbrain
Maybe one of the lowest mileage on a 02
Most definately. My 02 has nearly 34,000.
Old Aug 25, 2006 | 11:35 PM
  #35
DrkSlvrS's Avatar
DrkSlvrS
I just tagged on another 1,000 miles doing the first 2-legs of MTTS - what a fun car!
Old Aug 28, 2006 | 06:17 AM
  #36
05BRGS's Avatar
05BRGS
The was a yellow mini here in North Jersey for sale with 180K listed as mileage. I think they were asking 13K for it.
Old Aug 28, 2006 | 08:05 PM
  #37
HighSchoolzMINI
8200 n counting
Old Sep 2, 2006 | 07:21 PM
  #38
miniGarfield's Avatar
miniGarfield
my MCS 05 PH has about 18K
won't make the list either!
Old Sep 2, 2006 | 08:15 PM
  #39
dkstone's Avatar
dkstone
Originally Posted by IanF
dkstone's THDUKE ('03 IB MCS JCW) has over 130K last time I saw him post a few months ago. And that is with a brutal Long Island, NY commute and more than a few track days. Maybe he'll see this and post the latest tally.
Thanks IanF,
Just saw this post and you reply so here goes: 140K total 122K since the addition of the JCW and with the exception of a MAP sensor the engine and drive train is still a virgin no seal broken, 31 track days in 2005, 25 track days so far this year and still going strong.
Well I guess its time for a new car, I wonder what car I will get next? actually THDUKE will never be replaced and since I still can't afford my true dream car I will have to settle for 2007 M3, there i said it I am now committed.
Old Sep 2, 2006 | 09:28 PM
  #40
dbwilldo's Avatar
dbwilldo
Whoa! And I thought I was good:
Old Sep 3, 2006 | 10:21 PM
  #41
Adnuo's Avatar
Adnuo
Sorry to sidetrack a bit, but about the supercharger going bad -- can you just add more oil to it before 100k? I just broke 50k, and all of a sudden anything and everything that affects the longevity of any part of my MINI interests me more than ever. Can I expect to have to replace the supercharger, or will proper maintenance keep it running?
Old Sep 4, 2006 | 06:38 AM
  #42
C4's Avatar
C4
Another low mileage '02 MC CVT here, Barely 38.5K miles
My 4 year warranty expires on Thursday, the 7th
Car is running like a champ
On the other hand, my '05 MCS has 16.8K miles and it is 18 months old.
Old Sep 4, 2006 | 09:05 AM
  #43
Yo'sDad's Avatar
Yo'sDad
Lube the SC
There is no reason to just let the SC die because the oil gets low. They are so expensive that it surely seems smart to me to pull the water pump and check/add/flush/replace/whatever the lube in both ends every 50K or so.
I posted a thread in the 'under the bonnet' section of this forum about pulling the sc at about 40-50 and drilling and tapping an access hole in the side of the gear housing to install a place to add lube and let xs oil drain out. A location with an extension tube or pipe that could be more easily accessed. Then you could check the lube every time you changed your engine oil. No one seemed to jump on that band wagon. But I'll be damned if I'm going to let the sc chew itself up just because I let the lube go dry.
I'll be pulling the water pump and doing the lube maintenance on the sc no matter what it takes. At that time I'll see if my idea is worth doing or not. I just can't afford to drop big bucks on a replacement sc.
If you keep it lubed, I don't see why the sc should be expected to die at about 100K.
YD
Old Sep 4, 2006 | 10:16 AM
  #44
HighSchoolzMINI
YD
Thats true they run for $600-$800( ) bucks on ebay minus install
Old Sep 4, 2006 | 11:03 AM
  #45
Yo'sDad's Avatar
Yo'sDad
The re-mans they are talking about in the other section of this forum are a lot more than that. They are talking $1700 just for the part.
Old Sep 4, 2006 | 06:55 PM
  #46
HighSchoolzMINI
Well i think they might be talking about a new im pretty sure the one i saw on ebay was from an 05 that had some miles on it
Dec 23, 2015 10:36 AM
O4mcs
Aug 10, 2015 10:22 PM
ludedude
Aug 10, 2015 07:16 PM
Dashdog
Aug 10, 2015 06:17 AM
