R50/53 The Dangers of Driving Through Puddles
Originally Posted by Hammer
What about water getting sucked up through the exhaust pipe - fact or fiction?
Originally Posted by motor on
Well I don;t recommend it but I've forged water, driven through a CAT 3 (At full on highway speeds) hurricane and been in downpours with a CAI, no water damage. It has happened I think it takes 4 or so inches of water (which is ALWAYS deeper than it looks) so I could see where this has happenedin areas getting lots of rain, the real danger from water comes with the exhaust not the intake on a stock car because thats the easiest way for water to creep in. I'd say not really a myth, but there is excessive concern/I need an SUV menatality.
If it was able to mix with the oil then it properties would be as such where it could compress, and there wouldn't be this issue, so it is and indirect simpler way of think about it and something to remember before you decide to forge rivers in your MINI. Don't disagreeing with you at all.
What? It has nothing to do with water mixing with the oil... Its about the engine imgesting water and trying to compress it. Hydro-lock. You can compress a gas mixture.. but not a liquid.... at least not easily... The water entering the engine would not mix with the oil... it would be locked in the combustion chamber causing mucho damage..
Originally Posted by rameeti
My experience wasn't quite that way. When my Nissan Pathfinder was about 1 week old, I was skimming the surf along the Sea of Cortez in Baja California. The waves came in a bit faster than I expected and the water got into the wheelwell where my air intake was. I then proceeded to start floating in the sea until my buddies yanked my out with a strap. The engine wouldn't crank at all.I had to pull all of the plugs out and then crank the engine. Geysers of water popped out of the spark plug holes about 3 - 4 ft high. I dried the spark plugs, let the air filter dry in the sun for 1/2 hr, then put it all back together. Turned the key and it started right up. Worked great for about 8 years and then I sold it. Never did see any result from that experience.
This, and a few other NAM threads on the same subject, have really driven home the dangers of running the MINI through standing water, much more so than the owner's manual. It especially helps to know the mechanics of how the water could enter the engine. I live in an old part of an old city, where street flooding is pretty common after a heavy rain, so I've been paying attention to these discussions.
Thanks, everyone!
Just a note, an S with a performance intake CAN get through water that was inches from the windows. It happened to me on a road in my area. I was S#^$^ing kittens when it did but I pulled her through.
This is not reccomended, but the intake does not toss the water right into the engine like on a non-S and the performance intake makes it so even more water is needed in order to cause that damage. The car WILL TRY to stop, and likely one cylinder will stop firing as with mine, but keep pushing and praying and drive FORWARD to the closest edge and like me you may get lucky and have no damage at all.
The non-S has a key design flaw in that any water that can get into the mouth of that intake that overcomes the drain on it will drop right into your engine and you know what happens next...
My question about car wash spray going forcefully thru the scoop, is rather off-topic, at best it's a tangent, I know...
I understand that there's no direct path thru the hood scoop to the intake and then to the heart and soul of the engine... I just was thinking of that strong horizontal spray into the scoop like happens at a touchless car wash... Without fail it makes the tach dance up and down and the engine splutters. Doesn't stall but I always think it might. I do not fear hydro-lock, at least not at the car wash.
Willing to drive AROUND 12" of water, even though I trust the manual (except about checking the oil
Tatt
),Tatt
it may be getting on a belt causing slipage, or it may intermitantly be getting in some of the electronics.
Also know if you hose down the intercooler while running it WILL change the sound of the engine as it is adding cooling to the air/fuel mixture and therefore the engine will sound different.
I have ran 1 Cooper and 2 Ses (2 Cooper S cars, whatever) through touch free washes and never had an issue.
Ask your service TECH (NOT ADVISOR) what may be causing this and they may well have a better answer for you.
. I think I can buy into the wet electronics or (less so) the belt slipping ideas... From what I'm hearing (and thank you) I'm pretty much just not gonna worry about it, though stalling in the car wash would be lame.
Your advice about talking to a tech and not the "greeter" is well-taken,
Tatt
Tatt
),Tatt
I don't know any facts about it, but I thought I heard somewhere that MINI made a design change with the location of the air intake on later models to lessen the chance of hydrolocking regular Cooper (non-S) cars. Can anyone confirm this, and what year?
Tatt
),Tatt
One of my friends who is considering buying a 2007 MCSC asked me about this. At first, I thought it was some myth perpetuated perhaps by 350Z drivers. But, I was suprised at the multiple posting here and in the MINI2 forums about this.
But can someone just recap for me and confirm if what I understand is correct? What I understand is that due to some configuration that older MC's had allowed water to be sucked into the engine more easily than say a MCS, MCS JCW, or MCS with performance air intake.
Was this problem fixed in later years?
Does someone have photos that can point out the difference between the MC engine/intake and the MCS engine/intake that would illustrate why this can occur?
Thanks.
Thanks.
The only way on ANY car that it will hydrolock is from stupidity. I would almost bet money if you hit a puddle big enough to get that much water through your filter will throw the car out of control and into something doing far worse damage. Second the intercooler intake scoop and the car wash. There is no way water from is getting into the system from the front scoop. Third, exhaust....... no no no no. Trust me, Ive had water cresting over the hood of my Jeep and it runs like a champ. The only way you can do damage that way is if you turned the engine off in water that is higher than the exhaust manifold.
While this is extremely true, I thought I'd mention that I knew someone whose car hydrolocked because of someone else's stupidity. He was driving a VW GTI and found himself in water that he knew was getting a little too deep to drive through, so he slowed down and was going to find a way of turning around when a larger vehicle sped through the water to pass him. The wake from that vehicle toasted his engine, there wasn't much he could do. On smaller cars, I'd say just try to avoid deep water altogether if possible, you never know when other people around you are going to make an idiotic decision that might mess you up while they keep on going.
Very interesting, this hydro locked stuff, but has anyone considered the Mini's idiosincratic positioning of the power steering fan? That damn thing is only inches of the ground at or near the lowest part of the car in both 1st gen MC's and MCS's. Given this and the fact that water is far more viscous a medium then air is it would follow that the additional drag on a submerged PS fan would cause dome damage to it. I would bet that at the very least the fuse to the fan would blow and or the fan motor would melt. Ultimately with an an inoperational PS fan I would think the PS pump would overheat and fail. It doesn't matter if you creep or stall in water over 6" deep yourcar is going to have some expensive bills. Wonder how often this happens?
if you see standing water... find an altranate route. This is a rule of thumb for all cars. Don't drive through standing water. You can bend this rule if you know the road and have an idea how deep the water is... but it can be decieving so just find a different way around.
extremely unlikely to happen for two reasons.
first - it's sealed.
second - it has postive pressure inside. If it did have a leak and you submerged it it would blow a stream of bubbles. not suck water in.
come on here people, if you know anything about how engine works exhaust blows out and any liquid would have to climb up the header to the engine, where there are exploding gasses exiting, so never will a car exhaust suck up water
secondly engineers think of things like this when they build cars. They arent going to put an intake right in the line of fire of rain, bugs, dirt, and small birds
and as far as the water on the intercooler if anything it should cool it down and actually help performance, so you can spin those tires inside the bay! haha its pretty much like the Nitrous sprayers used on intercoolers in other cars (mostly front mount)
hydrolocking is a big problem on mini's. I've seen 4 of them with my own eyes granted 3 had aftermarket cai's... but who has a stock mini on these boards any way.
A friend of mine hydrolocked her '05 Cooper driving too quickly through deep puddles!
The intake is poorly placed on 1st generation Coopers...in fact my SA considers it a design defect!
Just be careful, you'll be fine!!!
