R50/53 Brake Dust on Wheels
Old Mar 13, 2006 | 04:09 PM
  #26
cushin14's Avatar
cushin14
I believe in preventative maintainence, some call it O.C.D.
I have the stock pads now so I have to clean regularly, like every other day, whether it's 30 or 90 degrees. I use this brush, purchased at Wal-Mart, which helps when it is cold on the hands and it also cleans the inside of the wheel very easily, so I have totally clean wheels....YeP! That's probably O.C.D.
Attachment 11471
As soon as I get my money's worth out of the factory brake pads I will be purchasing the "Green Stuff" brake pads, everyone I have talked to that uses them say way less brake dust.
As far as the original post here and using gasoline, that is too harsh to clean wheels with. Since you have used gasoline already I would try Eagle One Wadding Polish pictured below or Mothers wheel cleaner.
Attachment 11472
It takes some elbow grease and not sure it will work once gasoline has been used but I would give it a shot, and definitely keep the wheels waxed once you get the dust removed since the gasoline has most likely removed some of the protective coating the wheels have from the factory!
Good Luck!
Old Mar 13, 2006 | 04:18 PM
  #27
stargate823's Avatar
stargate823
Where exactly do you get the "green stuff" brake pads out of curiosity?
Old Mar 13, 2006 | 04:19 PM
  #28
MSFITOY's Avatar
MSFITOY
Brake dust I thought that was a myth...no matter how much I clean my wheels...they're still black
Old Mar 13, 2006 | 04:28 PM
  #29
stargate823
Nevermind, I answered my own question....
Old Mar 13, 2006 | 05:52 PM
  #30
bamatt's Avatar
bamatt
I believe in preventative maintenance too. I mean to look at my MINI after weekly wash day the wheels look sparkling clean & new. When you walk up & really look close up you will see that the out-of-reach areas have some black. I have no desire to scrub the out-of-reach areas on my wheels weekly so I am looking for something to do say monthly that won't damage my wheels. Also once I get em clean I am going to try the wheel wax to see if it helps any. The P21S gel is sounding like what I will try 1st. I will give it the true test on built up dust & let you know how it works out for a monthly wheel cleaner like me .
Old Mar 13, 2006 | 06:55 PM
  #31
TosaCooper's Avatar
TosaCooper
Our weather was finally warm enough Sat. to do the first handwash since late last fall. That first good wash of the year I've used Meguiar's Gold Class instant wheel cleaner. That and a wheel brush takes the built up dust right off my X-Lites. With the warmer weather it won't have time to build up again until next winter. I've used this process for two years now and haven't noticed any issues with the finish at all.
Old Mar 13, 2006 | 07:16 PM
  #32
ATCQL's Avatar
ATCQL
To elimate the cleaning i have installed Mintex Red Pads and am happy with the results.I have had them on my VW for years,same results.Q
Old Mar 13, 2006 | 08:06 PM
  #33
effusant's Avatar
effusant
Originally Posted by bosfordjd
I'm not really sure I recommend this, but whenever I can't get something off and I'm not particularly concerned as to what might happen I go with brake parts cleaner. I haven't encountered any sticky grimy oily substance it won't take off. I've hit plastic hubs and painted steel rims with it to take off brake dust with no ill effects, but never anything I'd consider valuable.
I've had alot of success using it to remove adhesives as well, it just seems to break them down if given the time, also seen it dissolve some foams. I always use it to clean my tools, top of the oil drain pan and funnels when I finish a job. It will also clean your hands real good after a day under the hood when gojo just won't get the job done, a quick spritz under the finger nails can save alot of scrubbing time, of course use the gojo afterwords unless you really enjoy the parts cleaner scent. I generally use the generic stuff from advanced auto parts stores, seems to work just as well as the brand name stuff like Brakleen.
As a chemist, I've got to recommend against using it on your hands. You even said in your post that you wouldn't consider using it on anything valuable... that stuff contains some very harsh substances. We had a guy at work int he production department who liked to wash his hands in the solvent baths. Not the same solvents as brakleen, but not entirely dissimilar from the naptha ingredients. He didn't make it past his early 50's.
Old Mar 13, 2006 | 08:18 PM
  #34
bosfordjd's Avatar
bosfordjd
figured it had to be bad, but I really didn't consider long term absorption problems. I just figured if it irrated my skin there was a problem, and it didn't so never really thought about it. Good thing someone did , guess I'll have to scrub a little harder with the gojo from now on. It's kinda expensive as a hand cleaner anyways.
Old Mar 13, 2006 | 09:16 PM
  #35
rkw's Avatar
rkw
Nevermind the wheels, do your hubs stay nice and clean like that? I don't like my center caps, but I use them anyway because I don't want exposed grungy, rusty hubs either.
Old Mar 14, 2006 | 05:48 AM
  #36
MSFITOY's Avatar
MSFITOY
To keep them from rusting, paint with Rustoleum. I rarely wash the hubs but then, I don't drive in the rain either
Old Mar 14, 2006 | 06:05 AM
  #37
Herby74's Avatar
Herby74
My routine: EBC Greenstuff brake pads; two layers of Zaino (Z2) car polish every 4-6 months;
Eagle One wheel cleaner. I still get brake dust, but less of it.
Old Mar 14, 2006 | 11:27 AM
  #38
Wesmonster's Avatar
Wesmonster
Originally Posted by bpago
I would stay away from gas or anything that harsh.
Waxing is somethin I had not thought about.
I use "CYCLE CLEAN" from local Motor Cycle store. THIS STUFF WORKS.
I even thought about buying in bulk, repacking and selling to the MINI world.
Funny you mentioned that, I had a full bottle of S100 motorcycle cleaner from my last bike and I used that on the wheels, then rinsed all the black dust off without scrubbing. Most of the comercial wheel cleaners I tried didn't work as well as the S100. It's expensive stuff but it works great. I think the trick is to get all the dust buildup from the inside of the wheel as well, which is one place you can't scrub, but you can spray & rinse...
Old Mar 14, 2006 | 12:29 PM
  #39
cushin14's Avatar
cushin14
You can use a brush like the one I posted a pic of in this thread and I am able to easily scrub all of the insides of the wheels. With the factory brake pads I clean them about every other day to avoid future buildup of dust inside the wheel. $4 at Wal-Mart or probably any auto care store as well. I use it with Zaino Car Wash or Meguiars Car wash to clean the wheels.
Will soon start using Zaino Wheel polish as well, but the brush works great for cleaning inside the wheels.
Old Mar 14, 2006 | 12:47 PM
  #40
flyboy2160's Avatar
flyboy2160
i had the same black specs. i suspect they are excess wheel weight adhesive, not brake residue.
after trying many things, i finally got them off using a claybar and mineral spirits.
Old Mar 14, 2006 | 01:03 PM
  #41
MINISPIDER's Avatar
MINISPIDER
You just want to show off your wheels and HUGE brakes-----show off!
Old Mar 14, 2006 | 01:28 PM
  #42
saakey's Avatar
saakey
yep - I echo the changing of the pads...but use Simple Green to clean the wheels - works great, it's non-toxic, and biodegradable
Old Mar 14, 2006 | 01:41 PM
  #43
W3IWI
The Real Solution
The real solution to the problem is to change out the stock brake pads, especially on the front. I use Greenstuff pads and even with polished aluminum wheels I can hardly see the dust.
The rears don't have brake dust problems as bad as the fronts. I still have the stock pads back there, but I'll put on Greenstuff pads soon with ~40k miles on the car.
Old Mar 15, 2006 | 01:27 PM
  #44
Archanum
Guest
Posts: n/a
Simple Green
Simple Green works pretty well. I hadn't "really" cleaned my wheels all winter and the other day when it got warm I used Simple Green and a little elbow grease and 98% of the gunk was gone. And I think if I hadnt been so tired already I coulda gotten the rest off.
Old Mar 15, 2006 | 05:05 PM
  #45
effusant's Avatar
effusant
another good idea: nitrile gloves. Or a medium thick latex if you're not sensitve yet. Automotive sludge tends to be rather carcinogenic itself. And it's a LOT quicker and easier to shed a layer of rubber than scrub out your fingernails at the end of the day. (they'll probably run about a dollar or two per pair if you buy a box of 50 gloves) And for what it's worth, they're more a barrier against physical debris than solvents. Most disposable gloves are fairly permeable to things like light ketones and aromatic compounds such as the constituents of solvent cleaning sprays and fuels. But they're excellent against almost all powders and waterborne chemicals.
Old Mar 15, 2006 | 05:43 PM
  #46
MSFITOY's Avatar
MSFITOY
mmmm....could be But I'm surprise no one's acknowledged my perfect solution for brake dust though
Old Mar 15, 2006 | 05:45 PM
  #47
daemon2's Avatar
daemon2
Keeping a good coat of Carnuba on the wheels helps with getting the brake dust off at the wash.
A little more elbow grease but worth the effort.
Old Mar 16, 2006 | 10:00 AM
  #48
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
Originally Posted by Chainsaw Flowerchild
I just use Mothers California Gold Car Wash, Mothers PowerBall and a Power Drill. Gets them real clean.
I thought that the commercial said that those products were for use on Chip Foose wheels only???
Didn't Gabe of White Roof Radio fame suggest wheel tear offs?
Old May 12, 2006 | 07:41 AM
  #49
cliffyb's Avatar
cliffyb
Once you get them clean apply Wheel Wax twice (as per directions). I have no problems with brake dust now. You will have to add another coat periodically, but its easier than tackling the dust. Order it from:
www.wheelwax.com
Old May 12, 2006 | 11:33 AM
  #50
caminifan's Avatar
caminifan
Agreed (about changing the stock pads). Except I changed to Hawk ceramic pads. Virtually no dusting and it seems the rotors have no wear. I definitely don't do the obsessing about weekly cleaning/waxing/etc. If that is your "thing", have at it. I prefer to drive the car.
