R50/53 grinding sound while turning right @ low speed
Old Mar 10, 2006 | 11:37 AM
frank miller's Avatar
frank miller
Any thoughts?
Old Mar 10, 2006 | 12:11 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Do you have the LSD- does it happen when you turn? If so, search for lots of discussion of this sound. I recently was in an 06 JCW and it grind-ed away just like mine does (05 MCS) so I conclude, based on a large sample of 2, that it's normal--or at least survivable.
cheers, phil
Old Mar 10, 2006 | 02:47 PM
ahamos's Avatar
ahamos
Coordinator :: River City Minis
If you don't have LSD, it could be a worn bearing on the wheel carrier or a stuck brake caliper.
Old Mar 11, 2006 | 05:55 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
I had a similar noise happening in my car. At first the tech said it was just wheel noise. I told him that I just got new wheels on the car and even the older wheels made the same noise (a sort of rhythmic droning).
Well they took a longer look at it and end up replacing the driver's side hub assembly. Part #7 on this page
Old Mar 11, 2006 | 11:24 AM
Barnabas's Avatar
Barnabas
sounds like your right CV joint's going bad...but it wouldn't necessarily limit itself to right turns...Check your CV boot to make sure it isn't ripped or anything on the right half shaft. It's the rubber boot by the transmission
Old Mar 12, 2006 | 01:10 AM
cooper99's Avatar
cooper99
OR... , if the grinding sound seems to come from a certain side and it sounds like metal on metal, it could be a heat warped brake dust shield behind your rotor; that's what I experienced last summer. If so, just bend it back with a screwdriver or something similar (sorry Onasled, Tuls, Webb Motorsports, Helix, Detroit Tuned, or any other expert, if that isnt the proper explanation on how to fix it but that's what I did. Of course feel free to correct me if needed).
Old Mar 13, 2006 | 02:17 AM
cushin14's Avatar
cushin14
I don't know what model you have but my '06 MCS makes a noise at low turning speeds.
This is due to the independent power steering pump motor, you only hear it at low speeds while turning...very common!
silence2-38554
Nov 12, 2015 09:39 AM
David.R53
Sep 1, 2015 06:51 PM
David.R53
Sep 1, 2015 06:49 PM
xpunisherx
Aug 10, 2015 10:50 PM
