R50/53 worst gas mileage ever!!!
Originally Posted by Electric Shock
Someone on MINI2 posted this. I followed this procedure and then for the first tank or two after the reset I drove like a gramma. I don't know if that is necessary but that's what I did and ever since my MPG improved by about 5 mpg.
1) With the key in the off position press and hold the speedo reset button, turn the key to position one and the screen will say test and a number.
2) Go through the list by pressing the reset button up to test 19 and then wait.
3) The display should then say"log i-off" then "log i-on" over and over again....when "log i- off" appears again press the reset button ....and now you are in the system software.
4) Scroll upto 21.0 Software reset. When reset appears press the button again and you will get a beep and you're speedo needle may vibrate a little (this is normal).
5) Turn ignition off then back on to position 2 for 10 secs then start your car and hey presto its done.
This reset sounds like a calibration of the speedometer and the trip computer. Maybe it compares data from the tire pressure since, over time, your tires are getting smaller and changing your final drive ratio? I'm just guessing.
The only way you're really going to find out your mileage is the old fashioned way, by tracking how much gas you buy and how far you drive over several tankfuls. It's also a good idea to check the calibration of your speedometer by measuring several miles along a highway with mile signs (any interstate and lots of others as well).
Let us know what you find out.
Originally Posted by Luthier
Actually MPG depends on how you drive...
When I drive like a gramma, means when I control rev at 2200 rpm max, my mpg goes up to 33mpg!
I ususally get 28mpg, though.
Originally Posted by rjmann
Man I hope this is a slushbox with a torque converter or a MINI D. Upshifting at 2200?!? Accelerating, even gently, from a say 1500 rpm can't be very good for the motor. One would suspect that ultimately this would result in substantial carbon build up.
Originally Posted by resmini
This is just a guess, and I was wrong once, but I don't think upshifting at 2200 RPM would cause any extra carbon buildup or and other negative effect.
https://www.northamericanmotoring.co...ock+dyno+chart
I'll simply relate what others have noted in the Porsche world, and admittedly this anecdotal in nature. 911 engines, particularly the last gen of oiol cooled ones, that have been babied, i.e. that just tool around and are not reved sufficiently high, have wound up with premature wear particularly in the valve train. The engines run too cool and crud builds up in them. This has led to some 911s have a reputation for premature failure of valve guides or worse and requiring top end job$$$. Certainly modern tolerances, the addition of knock sensors, etc. have somewhat eliminated the notion of lugging an engine, at least the computer seems to be able to eliminate the piston slap before we actually can feel or hear it. Nevertheless, Why do this as opposed to running more solidly in the torque band. Sort of negates the reason for owning the car in the first place. If fuel economy is the biggest concern, its probably best just opt for the MC anyway. All that said, I've been wrong way more than just once. Way more. Just my $.02
Originally Posted by CDMINI
That's funny, you really think this British manufacture has a computer that compares tire pressure and/or diameter of tires when computing MPG? I know it's just another equation, but REALLY???
Hello, I just got my MCS & after 267 miles when I filled up & figured the mileage it had gotten 27.8 mpg. Not bad for a brand new car with a engine that's not broken in. Cold weather too, so I'm guessing it will get better with time. You could say I'm pretty pleased.
Chuck
Chuck
If you think that's bad, in my Honda Insight, a 2200 rpm shift is a bit high
. I can cruise all day in 5th gear at 1000-1200 rpm getting 100-125 mpg
. It IDLES at 1k rpm. It also has 30 degree offset cylinders that allow this low rpm driving.
Originally Posted by kapps
2200 is a fine shift point for the higher gears as the rpm's don't drop that much. I try to keep the revs above 1800 rpm in 4th and 5th; 2k in 6th. 1st and 2nd can be driven in the 1200-1500 rpm range if needed. This is all for economy, of course.
I, or should I say my tranny program, shifts my F-250 at 2200 on light throttle, but this is a diesel and puts out something on the order of 560 Ft lbs at 2K (although it weighs close to 3.5 tons. Neither of these motors is high output on the order of 100HP+ per liter engine which the MCS is. So presumably there is different design criteria involved and therefore different tradeoffs in usage.
I filled up the 06 MCS at just under 800 total miles. Per the computer, average speed is 24 MPH, and average consumption is 24 MPG. I haven't been watching it closely, but I had to notice that they were the same.
This includes some fairly spirited driving (at under 4500 RPMs!), and mostly city driving as well as a couple of Beltway traffic jams that are worse than city driving. I'm filling it with 93 Octane premium per the manual.
Well Our 1500 mile R/t to the Dragon in May, "Merlin" avg 34.6 mpg 1200 miles highway 300 miles Smokey mountain stomping.
R/t to AZ a month ago 4500 miles total avg 34 2 mpg 4000 mile highway, 500 miles city mountain stomping
City Motorin avg 24/26 depending on my mood
Typically I'm in long traffic jams on Long Island and with some faster, but brief highway driving, I've found I tend to get between 21-24 mpg with my MCS 6-spd in these conditions. That's at least as good as my last car, and I'm not a pokey driver either, so I won't complain.
Originally Posted by not-so-rednwhitecooper
man, i think the winter fuel is killing me.
Ive been averaging somewhere between 20-21 MPG city highway mix for the past few weeks.
as of late.
Originally Posted by ururk
Same here! I normally get around 29~31 in my MC, but I've been getting around 25mpg
as of late.
as of late.
well, if they didnt make the gas 70% alcohol in the winter.....
