R50/53 any ideas for hibernating mini??
Old Nov 4, 2005 | 11:33 AM
dan cooper scooper's Avatar
dan cooper scooper
Hi! Just stored my mini away to hibernate for the winter.. any hints or suggestions to less the rust and damge to it? Or just to chat about minis! :smile:
Old Nov 4, 2005 | 02:05 PM
Yucca Patrol's Avatar
Yucca Patrol
Try a Car Capsule
An inflatable protective baggie for your beloved MINI!
I have also heard of similar ones which fill the bag with nitrogen to remove rust causing oxygen. . . .
Old Nov 4, 2005 | 04:06 PM
kenchan's Avatar
kenchan
hibernate a MINI? did you know that's illegal in the US?
are you asking like pumping the gas all the way to full, pumping
air into the tires to 40psi, unplugging battery or putting a trickle
charger on it, car cover, things like that?
Old Nov 4, 2005 | 04:33 PM
schernov's Avatar
schernov
Here it is from Miata guys. They know how to store cars for the winter:
http://www.miata.net/faq/faq3.html#Y
Old Nov 4, 2005 | 04:53 PM
anteken's Avatar
anteken
If you're not going to take it out every time the weather allows...then remove the plugs and put a squirt of oil in each cylinder....then replace the plugs. Make sure to disconnect the battery or even better, remove, put on wood and hook a trickle charger to it....Cover it and put it up on jack stands. Don't think you have to worry too much about rust but hopefully you have a garage.
cheers
TREX
Nov 2, 2019 07:31 PM
arf88
May 31, 2016 03:07 PM
Mini'mon
Aug 26, 2015 01:02 PM
kpl
Aug 11, 2015 04:52 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
