R50/53 obc diagnostics with pda/cell phone
Old Oct 3, 2005 | 11:32 AM
minimotoman's Avatar
minimotoman
has anyone messed with the obc diagnostics using the software that can be put on your cell phone or pda. i seen in a magazine and thought it was a cool idea. I dont remember the website address.
Big question is how usable is it and what can be done with it.
Old Oct 3, 2005 | 03:40 PM
mybroscoop's Avatar
mybroscoop
I am not sure what can all be done with it or the price, but my brother uses Auterra software on his palm and i have another friend who uses the same software on his treo 600. Another option is the BimCom that is coming out soon (hopefully) but i think you have to have a laptop for that one to work.
Hope this helps,
Ben
Old Aug 23, 2007 | 06:43 AM
naffets's Avatar
naffets
Has anyone used any other software diagnostics that work with palm or pc?
What do you like?
What do you use it for?
What don't you like about what you are using?
Has anyone tired this one http://www.autoenginuity.com/index.html and purchased the extended kit that monitors these sensors? Kinda pricey but it seems to be very complete.
MINI CVT Transmission SensorsControl Motor PositionCVT Fault - Gear Reduction Not PlausibleCVT Fault - Transmission Oil TemperatureCVT Fault - Wheel SpeedCVT Gear ChangeCVT Gear Oil TemperatureCVT Transmission Oil Temperature SignalEngine Speed (Specified Value)GIB Fault - EEPROM ChecksumGIB Fault ActivationP N SwitchSelector Lever Switch - -Selector Lever Switch - +Selector Lever Switch - DSelector Lever Switch - MSelector Lever Switch - NSelector Lever Switch - PSelector Lever Switch - RSteering Wheel Stalk -Steering Wheel Stalk +Transmission Limp Home ProgramTransmission Output SpeedVehicle Speed
MINI Cruise Control SensorsClutch SwitchCruise Control ActiveCruise Control EnabledCruise Control Operation DownCruise Control Operation UpCruise Control ResumeDeactivation 1 - ASC ActiveDeactivation 1 - Brake PedalDeactivation 1 - Clutch PedalDeactivation 1 - Engine Speed Outside of RangeDeactivation 1 - IO Button PressedDeactivation 1 - PND EngagedDeactivation 1 - Speed Below 70% of TargetDeactivation 1 - Speed Outside RangeDeactivation 2 - ASC ActiveDeactivation 2 - Brake PedalDeactivation 2 - Clutch PedalDeactivation 2 - Engine Speed Outside of RangeDeactivation 2 - IO Button PressedDeactivation 2 - PND EngagedDeactivation 2 - Speed Below 70% of TargetDeactivation 2 - Speed Outside RangeDeactivation 3 - ASC ActiveDeactivation 3 - Brake PedalDeactivation 3 - Clutch PedalDeactivation 3 - Engine Speed Outside of RangeDeactivation 3 - IO Button PressedDeactivation 3 - PND EngagedDeactivation 3 - Speed Below 70% of TargetDeactivation 3 - Speed Outside RangeDeactivation 4 - ASC ActiveDeactivation 4 - Brake PedalDeactivation 4 - Clutch PedalDeactivation 4 - Engine Speed Outside of RangeDeactivation 4 - IO Button PressedDeactivation 4 - PND EngagedDeactivation 4 - Speed Below 70% of TargetDeactivation 4 - Speed Outside RangeDeactivation 5 - ASC ActiveDeactivation 5 - Brake PedalDeactivation 5 - Clutch PedalDeactivation 5 - Engine Speed Outside of RangeDeactivation 5 - IO Button PressedDeactivation 5 - PND EngagedDeactivation 5 - Speed Below 70% of TargetDeactivation 5 - Speed Outside RangeTempomat Lamp
MINI Engine R50/R53 SensorsASC Request Torque ReductionASC RequestedASC Torque DecreaseASC Torque IncreaseBattery VoltageCatalytic ConverterComplete SystemCoolant TemperatureCoolant Temperature VoltageDuration of InjectionEngine Full LoadEngine Full PartEngine LoadEngine OffEngine RunningEngine SpeedEngine SynchronizedEVAP Test 1EVAP Test 2EVAP Test 3EVAP Test 4Fault - A/C Pressure SensorFault - ABSFault - Camshaft SensorFault - Coolant Temperature SensorFault - Crankshaft SensorFault - EGSFault - Fuel Injector 1Fault - Fuel Injector 2Fault - Fuel Injector 3Fault - Fuel Injector 4Fault - Fuel Pump RelayFault - Instrument Cluster DataFault - Intake Air Temperature SensorFault - Intake Manifold Pressure Sensor Fault - Intake Manifold Pressure Sensor Before CompressorFault - Pedal Travel Sensor 1Fault - Pedal Travel Sensor 2Fault - Tank Venting ValveFault - ThrottleFault - Throttle ControlFault - Throttle Position 1Fault - Throttle Position 2Fault -CAN BusFuel LevelFuel Pump RelayIdle (Specficied Value)Idle SpeedIntake Air PressureIntake Air Pressure VoltageIntake Air Pressure (Specified Value)Intake Air Pressure Before CompressorIntake Air Pressure Before Compressor (Specified Value)Intake Air Pressure Before Compressor VoltageIntake Air TemperatureIntake Air Temperature VoltageKnock Control AdaptionKnock Sensor VoltageKnock Start AngleKnock ValueKnock Window DurationKnock Window EnergyLimp Home Operation - Camshaft SensorLimp Home Operation - Crankshaft SensorLimp Home Operation - Intake Manifold Pressure SensorLimp Home Operation - Throttle PositionLimp Mode Operating Mode Pot. 1 (Adaption)Limp Mode Operating Mode Pot. 2 (Adaption)Long-Term CorrectionLong-Term Correction (Average)Lower Electric Stop Pot. 1 (Adaption)Lower Electric Stop Pot. 2 (Adaption)Lower Mechanical Stop Adaption 1Lower Mechanical Stop Adaption 2Main RelayMass Air Flow SensorMisfire Value over 200 RPM - Cylinder 1Misfire Value over 200 RPM - Cylinder 2Misfire Value over 200 RPM - Cylinder 3Misfire Value over 200 RPM - Cylinder 4Misfiring (Stage A)Misfiring (Stage B1)Misfiring (Stage B4)Mixture Adaption (Additive)Mixture Adaption (Multiplicative)MSR Request Torque IncreaseMSR RequestedOxygen Sensor 1 Before Cat.Oxygen Sensor 1 Post Cat.Oxygen Sensor ControlOxygen Sensor Downstream of Cat. (Raw Value)Oxygen Sensor Downstream of Cat. ReadinessOxygen Sensor Heating Downstream of Cat.Oxygen Sensor Heating Upstream of Cat.Oxygen Sensor Signal Downstream of Cat.Oxygen Sensor Upstream of Cat.Oxygen Sensor Upstream of Cat. - RichOxygen Sensor Upstream of Cat. (Raw Value)Oxygen Sensor Upstream of Cat. ReadinessOxygen Sensor Voltage (Upstream)Pedal Travel SensorPedal Travel Sensor 1Pedal Travel Sensor 1 AnglePedal Travel Sensor 1 VoltagePedal Travel Sensor 2Pedal Travel Sensor 2 AnglePedal Travel Sensor 2 VoltagePedal Travel Sensor AngleShort-Term CorrectionShort-Term Correction (Average)Smooth Running Value - Cylinder 1Smooth Running Value - Cylinder 2Smooth Running Value - Cylinder 3Smooth Running Value - Cylinder 4Spark Advance Angle - Cylinder 1Spark Advance Angle - Cylinder 2Spark Advance Angle - Cylinder 3Spark Advance Angle - Cylinder 4Spark Advance Angle (Specified Value)Tank Ventilation Solenoid ValveTerminal 15Throttle (Specified Value)Throttle AdaptionThrottle ClosedThrottle Valve PositionThrottle Voltage 1Throttle Voltage 2Vehicle Speed
MINI Heater/Air Conditioning SensorsA/C Compressor StatusA/C RequestA/C System StatusCompressor RelayElectric FanEvaporative TemperatureRefrigerant PressureRefrigerant Pressure Signal
MINI Immbolizer SensorsEngine Disabled CounterIgnition On CounterImmobilizer Communications Fault Immobilizer StatusIncorrect Answer ReceivedIncorrect Message ReceivedNo Successful CommunicationNo AnswerRandom Code InitializedUnsuccessful Communication Counter
wildwestrider
11
Jan 29, 2016 05:06 PM
OldElvis
Oct 5, 2015 07:31 PM
GoBadges
Oct 1, 2015 11:10 AM
jennster
Sep 28, 2015 06:19 PM
