R50/53 Speedometer Problem
Old Sep 26, 2005 | 03:37 PM
Mike in SC's Avatar
Mike in SC
Speedometer Problem
I have searched the forum and have not found this one...last Friday as I was driving to work, I looked at my speedometer at it registered 70 mph - I knew that I was not going over 55 - it was strange. When I stopped my car, the speedometer stopped at about 18 mph. When I got back in my car about 4 hours later, it still said 18mph. Once I got home, I disconnected my battery and it reset the speedometer.
Now is there any reason for concern? Has anyone else had this problem?
Old Sep 26, 2005 | 05:37 PM
lcubed's Avatar
lcubed
two temperature extremes of 18 and 70??
do you park in a meat locker??
Old Sep 26, 2005 | 06:10 PM
jdmarino's Avatar
jdmarino
you have your gauges mixed up
speedo, not thermo.
Old Sep 26, 2005 | 06:46 PM
lcubed's Avatar
lcubed
Originally Posted by jdmarino
speedo, not thermo.
he didn't specify which speedo was reading off
(the one which toggles with the temp or OBC
or the big one)
Old Sep 26, 2005 | 06:47 PM
not-so-rednwhitecooper
did you attempt a gauge reset test in the infamous TEST menu yet?
that may reset your gauges.
anyone have a link to the instructions?
Old Sep 26, 2005 | 06:50 PM
Battle Cattle's Avatar
Battle Cattle
what i had to do was take the whole thing apart still plugged in... start her up and set speedo to zero then reassemble her. once that was done the next few trips it will be off when you back up but eventually will work back correctly.
-Josh
Old Sep 26, 2005 | 07:15 PM
Mike in SC's Avatar
Mike in SC
Reset worked with battery disconnect, but
It did reset when I discontected/reconnected the battery. I am concerned that there may be a problem that will resurface. I only have about 1800 miles on my MINI, so I will check with the service manager, just wanted to have all available info before I called them! Thanks.
Old Sep 26, 2005 | 07:16 PM
Mike in SC's Avatar
Mike in SC
Wow, sounds dicey to me
-Josh
Thanks for the info - I am still under warranty, so I will be at the dealer to look at this issue.
Old Sep 26, 2005 | 07:17 PM
no big deal, probably just a electronics bug, we already have lots of them, lol
Old Sep 27, 2005 | 04:50 PM
ninjamini's Avatar
ninjamini
My speedo often says i'm going 8-10 mph at a full stop. Recently I was on the highway and going 80mph. Cars were flying past me and I was passing noone.
I took it to service and they said they could replace it if i wanted. Now that i think its wrong I will take it back to them.
embiggenedmini
Oct 15, 2015 12:36 PM
rckrzy1
R55 :: Clubman Talk (2008+)
Sep 7, 2015 07:51 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
Ladybug-S
Sep 1, 2015 07:07 PM
