R50/53 Love my runflats!
Originally Posted by eVal
Funny, we were signed up for the E90 event but then had other things we had to do. I'm not a fan of the new design so I didn't mind
Originally Posted by kenchan
40psi is a bit too high for normal driving... I think even on runflats.
I think the maximum cold PSI for the runflats is 51 so 40 is well within the safety margin.
Originally Posted by Azwed
I use 40PSi on mine seems to work great.
Speed channel runs a British show called Fifth Gear, similar to Motorweek or Car&Driver show. They tested the runflats on a BMW, and the test was to let the air out of all 4 tires, and then race the car on a road course at full speed (just to see what would happen or go wrong). They couldn't believe it, the tires actually did very well, and the lap times were not that much off of there normal times (slower obviously, but not what you would expect). What was really surprising was that he was able to control the car very well for the situation, and the tires never came off or caused other issues.
I spoke with the local Goodyear shop and they said they are fine with servicing these tires, they have been doing so for the Corvette folks for a few years now.
Hey kaelaria -
I'm with you!
..I like my runflats as well, and I plan on running on them at Pocono in July. In fact, I just bid (and won - yea!!) in an auction for 4 nearly-new Dunlop SP9000DSST's that I'll be picking up from the owner ina couple weeks.
- - m
I'm with you!
- - m
Run Flats Suck!
I just replaced my runflats with performance tires, and the difference is amazing. Gone is the metal-on-metal noise when I hit a pot hole or bump in the pavement, and I kept plenty of air in them. I don't dread every single bump. I bought a $20 air pump at Pep Boys. Run flats suck!
Originally Posted by resmini
I think the runflats are fine as far as ride and handling but I won't get runflats when I replace my tires. A tire that gets me off the interstate but then almost always needs to be replaced for 250 bucks or so is something i can do without. Having an MC, I'll either use my spare or a $5.00 can of flat fix and be on my way.
Originally Posted by MINIclo
Kaelaria, I think in our MINI Owner's Manual it suggests not going over 50 mph in a flat runflat. 70 is WILD!
Clover
Clover
Originally Posted by fishey72
Runflats are great until....you get a flat and have to deal with the aftermath.
1. Usually no one will repair it, even if it is normally repairable.
2. No-one stocks them localy, and even on-line companies has/had delays in getting them.
3. The expense, ouch.
My run-flat flat was 2-3 week aggravating ordeal afterward without use of my car.
1-3 does not apply to me. It costs me nothing, even if I ruined the wheel or needed a flatbed tow. They are in stock around here without issue.
Yes AAA, or my roadside assistance for that matter would have saved the day also. I'm not pretending I would have been stranded or anything. However, it would have been at least a couple hours out of the day, on the side of the freeway and in this case, a tow to a local tire shop.
THAT is the inconvenience I'm talking about. Saving that is worth every penny. It's not a huge deal but it's certainly not fun or enjoyable, especially when you are no where near home.
My friend, who is a service writer in a tire shop, doesn't stock runflats. So even if the shop can do it they don't have them in stock.
I asked my sister why she switched tires on her MCS when runflats ought to be have been more reassuring. She said the runflats were very uncomfortable over potholes and when she drove the car cross country it was difficult to find a dealer that could replace her damaged one. So she switched to standard tires and thinks the car feels and handles better. She also drives a Triumph TR6 so her criticism about discomfort came as a surprise. To each his/her own.
Mmmmm... I am on my second set of runflats and about ready to buy a new set of tires. I've not been unhappy with the runflats... and I got a bad flat once and they performed as they're supposed to and I had no problem getting it replaced out here in the corn fields. How do I know what I'm missing short of buying something else?
The story I referenced on Fifth Gear wasn't really about ride quality etc for runflats, but about the safety factor regarding tire blowouts. They ran various tests at speed, then caused blowouts on front then rear of normal tires to see how difficult the cars were to control following the blowouts. In each case, they had major problems controlling the cars, and usually resulted in severe spinouts. The runflats allowed them to control the cars, without issue. The part about the race track and 4 flat tires was just to see if they could. Just thought it was interesting results.
My '03 MCS came with the sporty Dunlop 17" runflats. One year and 13,500 miles later they needed to be replaced, even with rotations. At the time even Tire racks price was hefty. I ended up buying some P Zero Neros.
One year later and another 14,000 miles, it looks like I'm gonna need replacements again. I don't get it. Do I really drive that heavily handed?
How often do you rotate? and.... Have you checked your aligment?
. Do you commute to work on a race track?Not a flame,
Tatt
I still have my original 17" Dunlop Dsst9000s on my 04 MCS with 22,000 miles. I would say I drive "spirited". I rotated front to rear at 20,000. The former rears, which are now the fronts, could last another 10,000. The former fronts now just trail along and will go as far. Am I happy? Yes and No, they're hard and heavy, but I'm getting decent miles with them. I had one small puncture that a normal tire would have acted the same, and had it repaired at "Discount Tire" no problems. I'm going to go with a performance non runflat tire on the next set, I just can't see spending $200+ per tire.
I hafta respectfully disagree here. For all the talk about ride harshness, this just hasn't been my experience (which, admittedly, is short lived). Heck, I'm even running the JCW suspension! The only thing about them is that the probably don't over enough grip. Hmmm. Maybe I need some fly paper or something
It says on the sidewall of my Dunlop runflats, "max pressure 35psig". Maybe yours are different?
I think I can substantiate these findings. When I had my flat, I had no idea that there was no air in the tire. I was driving b/n 70 and 80 mph on I80 for 60 or 70 miles. Also, I was driving around town later that evening (still in denial about a flat), and the performance of the flat tire was as if it was fully inflated. Incredible, really. Yes, I thought that the warning light was just my first experience with German Phantom Electronics. How wrong I was!
