R50/53 Anyone remove warning labels from visor?
Old Mar 15, 2005 | 01:34 PM
Ol' Yankee's Avatar
Ol' Yankee
Has anyone attempted, or succeeded in, the removal of the air bag / seat belt warning labels on the sun visors?
My wife HATES them and even started to try to lift a corner to peel one off.
I stopped her so I could check it out here with you before she made a mess of it.
Old Mar 15, 2005 | 01:46 PM
Donna/Mike's Avatar
Donna/Mike
Sand Dollar Collector
Lots of people have done it with success. Here's a thread with some tips
https://www.northamericanmotoring.co...r+bag+stickers
Donna
02' CR/W MCS (gone to MINI heaven)
05' Cool Blue MCSC
Old Mar 15, 2005 | 01:52 PM
Grumpy's Avatar
Grumpy
Here's what worked for me...
There is a very simple way to accomplish this. Grab a can of Goof Off (Home Depot has it as probably Lowes and others as well). Take some masking tape and line the borders of the label to protect the visor.
Take the Goof Off and apply it to the label. Let it sit for about a minute or so. Finally, start to peel back the label until it comes off. That's it! Works like a charm.
Old Mar 15, 2005 | 02:06 PM
cayucosteve's Avatar
cayucosteve
Remove Labels
It's called GOO GONE !!!! It works on any labels and great for stains when doing laundry.
Old Mar 15, 2005 | 02:25 PM
Grumpy's Avatar
Grumpy
What I used is called Goof Off not Goo Gone :smile:
Old Mar 15, 2005 | 02:42 PM
WindMeUp's Avatar
WindMeUp
Don't spill Goof Off anywhere, it will wreck the dash if it gets on it. Goo Gone is a little safer if you end up using that.
Old Mar 15, 2005 | 02:44 PM
cafejane's Avatar
cafejane
Lots of different techniques (good and bad) can be found here: http://www.gbmini.net/mtblog/archive...ite_head.shtml
The one thing that really caught my attention was the person from MINI2 who said they removed the visors from the car before applying any solvent. This would seem like the right thing to do especially after reading Ian's experience in the link above.
Let us know what you did and how it turned out.
Old Mar 15, 2005 | 02:48 PM
asodestrom's Avatar
asodestrom
You can use denatured alchohol also.
Old Mar 15, 2005 | 03:13 PM
namwob's Avatar
namwob
Remove the visors ---probably me. I used alcohol. Rather than blotting, I unrolled a couple of cotton *****, soaked them and spread them over the stickers. After about 5-10 min. ***** up a corner with your fingernail, then roll it up with a finger. Don't rub anything on it,the ink will smear off onto the visor (more work)
Old Mar 15, 2005 | 03:23 PM
speedn16v's Avatar
speedn16v
You can heat a label with a hair dryer too. The adhesive will soften, and peel easier. You can follow up with the denatured alcohol to remove any residue.
Dave.
Old Mar 15, 2005 | 03:35 PM
brgfan's Avatar
brgfan
*Don't* try to peel it off with a fingernail, you'll just scratch the visor. I'ts printed directly onto the visor with a rubberized ink. It is not a removable sticker. However the rubberized ink can be softened and removed with a number of substances. I used simple isopropyl alcohol from the medicine cabinet. Just keep rubbing the 'sticker' with a rag dampened with the alcohol until it starts to get gummy and wad-up. Keep rubbing till t rubs off.
Old Mar 15, 2005 | 10:52 PM
Nick_T.'s Avatar
Nick_T.
It’s very likely that there is more than one type of “sticker” used on the MINI sunvisors. On BMWs of the same year and model there are at least three types: (1) a sticker that can be peeled off with a little chemical help, (2) a type that appears to be silk-screened onto the visor and requires a lot of scrubbing with Goof Off, (3) an intermediate type that can be scrubbed off with alcohol or Goo Gone.
The stickers on my ‘04 were similar to the intermediate BMW type. Goo Gone was working, but not very well, so I switched to Goof Off - scrubbed with cotton *****. On my '02 Z3 they were type (2) and were pretty difficult - a lot of determined scubbing with Goof Off.
It’s well worth the small effort to remove the visors and do the removal elsewhere - makes the task much easier and there’s no danger of spotting the MINI’s interior.
Note that a lot of scrubbing with Goof Off will soften the vinyl and allow it to stretch - the visor will look as though it is ruined beyond repair. When you are finished just wash it off with mild soapy water and after about 20-30 hours it will have tightened back up and look like new again.
As brgfan said, don’t pick off the little pieces with your fingernail or any kind of tool - you will leave permanent marks on the vinyl! Change cotton ***** frequently and just keep wiping and scrubbing - you should be able to get every tiny piece of the sticker off in less that 20 minutes. If you’re very lucky you’ll have the type than just peels off and all you’ll really have to do is get rid of the adhesive.
Old Mar 15, 2005 | 11:41 PM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
The dash I just ripped off, but on the visors I used denatured alcholol.
BTW I also rip the tags off my pillows.
Old Mar 16, 2005 | 06:19 AM
Rick-Anderson's Avatar
Rick-Anderson
I'm calling homeland security on you!
Old Mar 16, 2005 | 06:50 AM
goaljnky's Avatar
goaljnky
Amature. Talk to us when you start ripping them of matresses.
Old Mar 16, 2005 | 06:55 AM
namwob's Avatar
namwob
If you rub chemicals on it it smears the ink all over the visor ,just soak, once its softened ,yes ***** a corner and roll up. then some gentle rubbing to remove any residue. If you remove the visors you can soak both at once.No spills or sore neck,no stinking up the car.
Old Mar 16, 2005 | 08:50 AM
Califzeph's Avatar
Califzeph
I just kept mine on... sorta like having "warnings of eminent death" stickers to scare the passengers...
I did peel off the one on the dash though, and cleaned the surface with GooGone.
Old Mar 16, 2005 | 09:32 AM
Herby74's Avatar
Herby74
I ultimately decided that removing the warning labels would also take away
the original, 'factory fresh' feeling of the cabin. They are intended to be permanent.......otherwise they would have been designed to come off easily. As an adult with a mild form of ADD I actually appreciate anything anyone wants to do to help keep me focused on the driving while I'm behind the wheel.
Old Mar 16, 2005 | 09:34 AM
ImaVunDerBrah's Avatar
ImaVunDerBrah
I am absolutely desperate to get to my MINI and get those horrid sticker things off now. This thread has me inspired... must. be. patient.
Old Mar 16, 2005 | 02:43 PM
sndwave's Avatar
sndwave
Those tags don't even make it out of the store.
I go matress shopping just to add to my collection.
To top it off I call the matress police on the people I've ripped the tags off of.
Old Mar 16, 2005 | 04:06 PM
SwingMCS03's Avatar
SwingMCS03
What's the trick to removing the screw covers on the mirrors (obviously I'm challenged in the do-it-yourself area)? I don't want to mangle them trying to get them off.
I would prefer to tackle this task sitting down at a table rather than looking up at the visor and possibly getting Goo Gone (or whatever I end up using) on something I shouldn't.
I've now heard alcohol, Goof off and goo gone. Which is the safest and easiest to use?
Thanks for your help.
Old Mar 16, 2005 | 06:12 PM
Nick_T.'s Avatar
Nick_T.
SwingMCS03 - -
I popped the covers off using a small screwdriver with a thin blade.
Alcohol is least aggressive, but safest. Goof Off is most aggressive, but least safe. Goo Gone falls in the middle.
Old Mar 16, 2005 | 07:24 PM
namwob's Avatar
namwob
Originally Posted by Nick_T.
SwingMCS03 - -
ditto what Nick says. If you don't have a small screwdriver handy,smack the end of a paperclip with a hammer & dull the end with sandpaper. stab it in the front or side of the button & it will move out the more you push in. Remove screw.remove black cloth tape covering connecter for mirror light & unplug connecter. If you use denatured alcohol make sure its 91% isopropal rubbing alcohol rather than the weaker version. If you do use alcohol cover it with toilet paper/unrolled cotton ***** so it won't evaporate so fast. leave it alone for 10 -15 min. roll it up. Then you can unroll it under the toilet seat or somewhere equally useless.
Old Mar 16, 2005 | 07:25 PM
Rennie's Avatar
Rennie
I destroyed the clear plastic cover showing what gear I was in when I used Goof Off in my last car. You have to be very careful with that stuff....it completely ruins clear plastic. Makes them hazy.
Old Mar 16, 2005 | 07:54 PM
Ryephile's Avatar
Ryephile
Just soak a rag in Denatured Alcohol and rub the labels for several minutes each - they'll "melt" and you'll be able to roll and peel off the labels.
Cheers,
Ryan
