R50/53 Windshield cracks
Old Dec 15, 2002 | 06:21 PM
GP53's Avatar
GP53
Has anyone experienced windshields cracking? Mine has an growing cracking coming out from under the lower left corner of the windshield with no obvious points of impact, etc. It looks to have started at the edge of the glass beneath the frame.
Old Dec 15, 2002 | 06:43 PM
dave's Avatar
dave
pug poo picker-upper
My MINI is on windshield #4
5 months 4 windshields
Old Dec 19, 2002 | 01:22 AM
mini4usa's Avatar
mini4usa
My windshield stress crack started at the top middle of the windshield just to the right of the rearview mirror.
My dealer Hank Aaron in Atlanta
checked it out and determined that it was a stress crack and replaced my windshield under warrenty.
The dealer was most helpful and provided me a loaner car for two days while my car was repared.
Old Dec 19, 2002 | 09:12 AM
docjchan's Avatar
docjchan
I got my first crack today, but I think I took a hit from a small rock yesterday, then this morning I noticed a small crack just below my left wiper. Within a half an hour of driving the little crack became a 6 inch crack.
Anyone know if the replacement has improved in quality ?.
Old Dec 19, 2002 | 09:19 AM
sirron's Avatar
sirron
Apparently the MINI windshields are made of very thin glass to save weight. I hear that hundreds of them have cracked. Let's hope that BMW replaces them with heavy, strong glass made in the good old US of A.
Of course that'll make your MINI slower.
Old Dec 19, 2002 | 09:22 AM
julianvh's Avatar
julianvh
I have a quetion.
The fellow Mini owners that suffer Windshild cracks have Sun roof?
Just a crazy idea...
_________________
Julian Vasquez
Old Dec 19, 2002 | 10:21 AM
kesh420's Avatar
kesh420
>>I have a quetion.
>>The fellos Mini owners that suffer Windshild cracks have Sun roof?
Good Question ! I am thinking it may relate to the frame flexing over a period of time due to having less support with the sunroof option. I have the hard top and the car is very solid, no cracks in the winshield, no body torque feel under hard driving as with my old VW.
Kesh
Old Dec 19, 2002 | 12:02 PM
Frenchbuly's Avatar
Frenchbuly
Barb
Old Dec 19, 2002 | 04:11 PM
dave's Avatar
dave
My MINI does have a sunroof, but I don't think that has any thing to do with it. Many MINIs without sunroofs have had their windshields crack. I am friends with one of the MINI Service Techs, and that isn't the reason for the cracks. The problem isn't that the MINI with the sunroof is less stiff than the MINI without the sunroof. The MINI is very stiff in torsion either way.
Basically, as I see it, the problem is this. MINI has very thin window glass. From what I saw from a random sampling when the windown installer came out, most companies windshields are 40% thicker than the ones MINI uses. That, in my opinion, is what is causing these problems. It not only predisposes the MINI to stress cracks, but also makes it more prone to rock chips (the more vertical window glass surface doesn't help either).
Old Dec 19, 2002 | 04:14 PM
2minis's Avatar
2minis
DID,
The only one I've seen had a sunroof.....
Old Dec 19, 2002 | 04:15 PM
julianvh's Avatar
julianvh
OK.
Thanks for the explanation.
Just read something about torsion and sun roofs someplace a few years ago.
Old Dec 19, 2002 | 04:50 PM
jimmer0's Avatar
jimmer0
There was a thread on here a while ago that mentioned some metal spurs in the windshield frame that caused the cracking.
Anyone remember who it was that had their windshield fixed and then found out about that??
Old Dec 19, 2002 | 04:55 PM
dave's Avatar
dave
It was SilkGreenGreg in this thread
Originally posted by SilkGreenGreg:
2. I’m hoping my stress-crack problems are over. After much investigation, there appears to be a problem on some MINIs with the finishing of the windshield frame where it meets the firewall—on some of them a small sliver of metal (as it was described to me) is left protruding from the frame and this uneven pressure on the tightly-fitted windshield, combined with a bump or pothole, can be enough to cause a stress crack. Kevin said that since discovering this, they have found the same problem on every MINI that has come in with a stress crack.
Old Dec 19, 2002 | 08:01 PM
Ben's Avatar
Ben
My MCS was delivered with a small chip in the windshield. My salesperson saw it first, and said they'd replace it. They did, twice. The first one they put in was cracked. Each time it has to "set" for 36 hours I was told. Now it rained, and I've got water running down the inside of my windshield. Yikes ... it's going to go back to the dealer again! How am I going to get this thing broken in so I can have some real fun?
Old Jan 30, 2003 | 06:55 AM
LockjawDavis's Avatar
LockjawDavis
Old Jan 30, 2003 | 07:01 AM
2minis's Avatar
2minis
>>DID,
Now I have seen one without a sunroof....mine.
Lower left hand corner about 4 inches.
Old Jan 30, 2003 | 07:05 AM
LockjawDavis
DAMN!!!! Got in this morning and, sure enough, I noticed a three inch crack coming from the lower left corner (passenger side) of my windshield! By the time I got to work, it was a 6 inch crack. There's no impact point. I go in to the dealer tomorrow to get new snow tires. How has MINI handled this windshield problem with others? Will they pop for a new one or am I *#@* out of luck????? :???:
Old Jan 30, 2003 | 07:08 AM
2minis's Avatar
2minis
Old Jan 30, 2003 | 07:09 AM
~Scooper~'s Avatar
~Scooper~
>>>>DID,
Minor damage to the MINI, right? As long as the monkey's OK...
Old Jan 30, 2003 | 09:16 AM
SilkGreenGreg's Avatar
SilkGreenGreg
Yes, I had repeated problems with stress cracks when I first got my MINI and my dealer found a metal spur or something that had not been finished off correctly on the frame. . . *anyone having stress cracks should have the dealer check this*. Once they found this and filed it down, I had no more problems. Here's the chronology:
10/19/02--picked up the MINI, odometer reading 25
10/28/02--stress crack, odometer reading 621
11/6/02--stress crack, odometer reading 1300
11/13/02--stress crack, odometer reading 1635
They discovered and fixed the spur while repairing this last crack. I am now at 4831 miles with no more cracks so I'm confident that took care of it.
Good luck. . .
GE
Old Jan 30, 2003 | 01:33 PM
LockjawDavis
GE,
Thanks for the info! My crack appeared at 2200 miles. I'm hoping your dealer did the work under warranty. Also, I keep hearing stories about dealers keeping the cars for 3+ days to install the windshield. Does anyone know the reason for this? Last time I had a windshield replaced (on a Jeep Cherokee), they popped it on in a few hours and off I went.
_________________
2003 Cooper/IndiBlue/AllPackages/Sunroof
Old Jan 30, 2003 | 07:52 PM
SilkGreenGreg
Yes, my work was done under warranty. My dealer said that the windshield has to set up for 24 hours after installation.
GE
Old Jan 30, 2003 | 08:32 PM
Xeon's Avatar
Xeon
Well about 2 weeks ago (that is what 1000 miles now ahaah) on my way back to central Texas from dallas it was the first freeze we had had and low and behold monday morning small crack now 2 weeks later HUGE and spidered into 2 cracks. The original ones total lenght is about one foot!! I goto the dealer sat so they can INSPECT it for warrenty worka nd ORDER the glass.... then once the glas come sin illhave another 3.5 hour drive to the dearship to have it replaced! ahahah grrrrr
but damn i doo so love my car
Old Jan 31, 2003 | 09:39 AM
KPiglet's Avatar
KPiglet
Misery loves company. My crack appeared yesterday. Same place....passenger side near the bottom and it's slowly creeping over to the drivers side. Earlier this week I got hit with a rock kicked up from a truck but I didn't notice any chip, crack, etc. at the time. I thought that the cold weather (ie-freezing cold windshield and hot defroster) may have brought out the crack a few days after the rock hit but now I wonder if that's what really caused it. I called my insurance company and it will cost me a $250 decuctable to replace. grrrr....If I take this to my dealer to see if it's a stress crack, will that be covered under warranty?
_________________
My girl Holly. Happy motoring!
Old Jan 31, 2003 | 09:53 AM
dave's Avatar
dave
[quote]My MINI is on windshield #4
_________________
You Can't, You Won't And You Don't Stop.... 500 of 1000
