Yes, this is true. Will run too cold without the thermostat, though, so the ECU will never sense enough engine temperature to switch to a warmed-up running state. Probably will throw P0128 and possibly P0125 as well....
did not mean to say this is something that would be a solution. just a troublshotting step. if you overheat with the tstat out, the tstat is not your problem.
also, if you take the tstat out you can flush the system with the engine cold / off.
set it on fire
just kidding, hoping to get chance to mess with it some more this weekend
thanks to this thread, i have a bunch of things to check out as i continue to try to trouble shoot it
(looks like i'll probably also need another gallon of that special MINI blue koolant juice & distilled water)
