R50/53 Transmission Fluid Replacement
Old Oct 19, 2025 | 07:52 PM
MikeW2's Avatar
MikeW2
Hi everyone,
I want to replace the transmission fluid in my CTV 2005 Cooper R50 (hatchback). I looked under the car today and realized the gearbox looks different from what I saw in the manual/internet resources. I think it is a GACVT16Z-UZ. I'm attaching a picture of it. Does anyone one have any experience in fluid replacement for this type?
Best
Mike
Old Oct 20, 2025 | 05:08 AM
noodlesandsam's Avatar
noodlesandsam
Careful there. How many miles, and any symptoms of shifting issues? The cvt is known to be troublesome. You may find lots of debris in there.
Old Oct 20, 2025 | 11:15 AM
MikeW2's Avatar
MikeW2
174 k mi. Last change was done at 74 k at the mechanic. I'm having issues with acceleration, drives normal within 50-60 mi/h but noticeable lower acceleration especially uphill and when AC is on. Struggles to drive over 65 and I need to rev up to 3500 to maintain 70-75 on flat stretches. Fyi checked vacuum and fuel pressure at rail (normal behavior). Has new O2 and map sensors, new sparks and coils, fuel filter and injectors. Engine has significant wear, compression in one cylinder is low but within range (150 PSI) and 40-60% leakage. The acceleration issue appeared relatively recently. Thought that maybe the issue is caused by old transmission fluid. Might be wishful thinking. Any comments/suggestions?
Old Oct 21, 2025 | 10:51 AM
Hello,
The older CVT info is here: https://www.northamericanmotoring.co...nsmission.html
Old Oct 28, 2025 | 08:51 PM
MikeW2's Avatar
MikeW2
Thanks!
Old Oct 29, 2025 | 07:11 AM
Welcome!
joluga123
Mar 5, 2020 08:24 AM
cybershelby
Mar 14, 2014 03:00 PM
nap220
Factory JCW Talk (2009+)
Feb 12, 2014 07:18 AM
mikesminicooper
Cooper (non S)
Jul 14, 2010 02:50 PM
