R50/53 Secure Keys secure no more?
Someone can't send out a signal and wait for the key to respond. The key signal isn't strong enough to work more than 6 inches away. If you take the ignition switch out of your car and turn it with a screwdriver the ign. will come on, and the car may crank on early MINI's, but there will be no ign. or fuel. Then you can take your key and hold it close to the ignition antenna ring and then it will start, but unless the key is less than 6inch away the car won't pick up the signal and won't start. Also don't forget the key code is rolling code so it changes everytime you use it. I hope this helps explain. Basicly the only way to steal your MINI is tow it away.
Originally Posted by mbabischkin
Not only that but it didn't say how long it actually takes one of these devices to crack the code. Think about it, if it takes you what 15 seconds to open your car door and it takes this device 30 seconds or more take actually brute force this code...Then it's longer than the bad guy would be near you...
Not only that but the bad guy needs to be 12 inches away, don't you think a stranger standing 12 inches away from you while you open you're car might be a little suspecious?
The best hope, stalk you as you get out of your car and stand next to you at an elevator...
Earl
Don't believe it could happen?
The RFID Hacking Underground
They can steal your smartcard, lift your passport, jack your car, even clone the chip in your arm. And you won't feel a thing. 5 tales from the RFID-hacking underground
http://www.wired.com/wired/archive/14.05/rfid.html
newminijcw
Oct 21, 2015 02:37 PM
MINI Stupor
Oct 1, 2015 11:36 AM
jennster
Sep 28, 2015 06:19 PM
