R50/53 Wheel / Tire Fitment
Old Dec 21, 2023 | 09:29 AM
  #26
jcampbell6768's Avatar
jcampbell6768
@Whisky B
I was looking at it yesterday as I thought it was rubbing against the inner liner; it’s actually rubbing the plastic fender trim pieces. There looks to be enough room to trim the inside of the plastic without compromising the “look” of the trim. I definitely can’t get rid of them (I could, but don’t want to) so I will “tinker” with the trim, possibly replace the rear control arms, and keep going
Old Dec 21, 2023 | 09:39 AM
  #27
Whisky B's Avatar
Whisky B
Right on man, if you have a Dremel or one of those Wizard things you should be able to make quick work of it. The situation would be a lot worse if you were rubbing on the back end against the suspension, should be an easy mod. Try not to completely eliminate the plastic lining as it does shield the suspension components from excessive moisture and debris, good luck
Old Dec 22, 2023 | 08:18 PM
  #28
jcampbell6768
@Whisky B
Definitely not rubbing on the suspension
Got the Dremel, just need a cutting wheel for it. Should be like butter!
Thx!
I also ordered a set of rear lower adjustable control arms to bring the wheels more into alignment; camber, I think?
Last edited by jcampbell6768; Dec 22, 2023 at 08:20 PM. Reason: Adding additional information
Wayne Sakamoto
R58 :: Coupé Talk (2012+)
Oct 24, 2018 01:14 PM
MINI VINI
Nov 23, 2012 12:56 PM
Parogie91
Oct 3, 2009 04:13 PM
jolson
Tires, Wheels, & Brakes
May 7, 2009 10:37 AM
jefeant
Jul 29, 2006 06:20 PM
