R50/53 Steering Angle won’t stay calibrated after Chrono upgrade
Old Jan 8, 2022 | 02:16 PM
jjcsnlynn's Avatar
jjcsnlynn
I am doing a Chrono pack upgrade for a friend and the Steering Angle Calibration won’t hold after the key is re-cycled. His car is an 06 S Automatic.
The new Chrono was programmed with INPA by a trusted mechanic with NCS-expert experience. He also has INPA for codes.
After install, I reset the lights and codes and then calibrated the steering angle. If I don’t turn the key off, I can drive and get no lights or codes. As soon as the key is turned off and car is driven again, I get the following codes and I can verify the Steering Angle is -1440. In fact, I can calibrate it to 0, turn off the key and check it without moving and it always reads -1440.
5E43-Abs/Dac- Steering angle sensor- Internal
0B-LWS Sensor/vehicle allocation incorrect or not available
I swapped the chronos with my 06 S Manual, and neither one would work in each other’s cars, but I didn’t reprogram them with NCA-expert .
Last detail is the alignment is off a little (Steering Angle of +4-5 on Foxwell when driving straight on different types of roads). Could that be part of my problem?
Old Jan 8, 2022 | 06:29 PM
A383Wing's Avatar
A383Wing
my car kept throwing a steering angle sensor code because of the VIN mismatch
Bryan
Old Jan 9, 2022 | 11:44 AM
jjcsnlynn's Avatar
jjcsnlynn
Bryan
So do have a constant DSC and Low Tire light on?
Old Jan 9, 2022 | 01:48 PM
A383Wing's Avatar
A383Wing
Here are my findings when I installed this Chrono-pack into my '06 R52 JCW earlier this year
1) The mileage on the cars odometer will change to read the new center dash cluster's mileage, I went from 108,000+ down to 84,694 miles
2) My TPS or flat tire monitor light is always on now, I can not turn it off with the reset procedure
3) My DSC light is on all the time as well, throws a code saying VIN is different between old & new instrument cluster
4) Also have other codes in the speedometer cluster, and the steering angle modules because of VIN difference's, I cannot clear the codes at all
5) My back up warning system, or PDC system does not work anymore
6) I don't think the "Check gas cap" light will function either, I drove around for a while with the gas cap loose, light never came on
7) I had to get another dash bezel with the chrome rings because the NAV system takes a different bezel
8) All gauges in the Chrono Pack do work when I plugged the instrument cluster into my car. All the dash lights work and dim as they should.
Bryan
Old Jan 9, 2022 | 02:17 PM
jjcsnlynn's Avatar
jjcsnlynn
Bryan
One last question. Do you have an automatic or manual? I did this upgrade to a few manuals and the lights go out after steering angle is reset.
Old Jan 9, 2022 | 02:54 PM
A383Wing's Avatar
A383Wing
mine is a 6-speed manual
Bryan
Old Jan 10, 2022 | 06:18 PM
jjcsnlynn's Avatar
jjcsnlynn
My son is a dealer technician and used his Autel scanner to do the steer angle calibration and it worked and stayed calibrated. Took it for a drive, shutting it off every few miles, and everything works as it’s supposed to.
Apparently the Foxwell SA calibration doesn’t work for Mini’s. I was doing some reading and the Foxwell, Schwaben and C110+ don’t always work for SA calibration. The weird part is that it will calibrate the SA on my 06 MCS.
Good news it it’s fixed and going back to my friend.
Tombstone
Oct 10, 2021 12:23 AM
A383Wing
Mar 2, 2019 05:51 PM
Lex2008
Aug 15, 2015 01:49 PM
rosaymaan
Oct 11, 2014 01:46 PM
