R50/53 Rattle when rolling, coasting, or in neutral.
Old Dec 30, 2021 | 06:08 PM
Zagnutbar's Avatar
Zagnutbar
Last week I installed a new passenger side axle, new wheel hub, new lower control arm bushing. In my 04 r53.
I also installed the VT performance dogbone lower mount.
Every thing is great except....
When in neutral or in gear but there is no positive or negative momentum force... there is a speed based rattle under the car.
If I brake it stops...if I accelerate it stops.
Doesn't matter if in 6th gear and coasting at 75 or rolling in neutral at 20mph... the rattle is there.
either the dogbone is not tight enough..
the bolts for the Carrier clearing aren't tight enough... maybe the carrier bearing is bad on the new axle???
or what? I am open to thoughts and ideas..
Thanks all!
I have enjoyed these forums for some time, and I would love some help.
Old Dec 31, 2021 | 04:20 PM
MiniManAdam's Avatar
MiniManAdam
Community Builder
I just replaced my lower amount thinking it was bad though it was going bad the main culprit was the upper mount on the passenger side ( replaced lower and knowticed upper moved freely and was bone dry). Either that or you have a bad balljoint
Old Jan 1, 2022 | 08:59 AM
Zagnutbar's Avatar
Zagnutbar
Upper mount
The upper engine mount? I am assuming.
I have a VT in a box.
maybe i broke the upper mount when i changed the lower...
Old Jan 1, 2022 | 08:16 PM
Zagnutbar's Avatar
Zagnutbar
Upper mount looks good. No bottom leaking no metal resting on the canister...
Can the carrier bearing go bad or have been faulty?
Hawaiidabest
R60/R61 Stock Problems/Issues
Nov 25, 2021 08:41 PM
java-mini
Mar 9, 2014 01:26 PM
minismitty
Jan 5, 2012 08:05 PM
user 73972
Jan 1, 2012 09:13 AM
beemer2002
Dec 3, 2008 08:01 PM
