R50/53 Crank Pulley issue
Old Oct 27, 2021 | 05:19 PM
Brandon Fluharty's Avatar
Brandon Fluharty
Crank Pulley issue
I have kind of a interesting issue my Alta 2% crank pulley is wobbling and i believe is the cause of my front main seal leaking i am aware of the stock pulley causing this but i didn't think a alta one would too i went ahead and ordered the 2% ati pulley and a new seal but i just want to see if that is the cause or if something else did it
Old Oct 27, 2021 | 06:55 PM
Nicefeet's Avatar
Nicefeet
Yeah just put that Alta pulley where it belongs, in the bin with the beer cans. Those lightened pulleys are a great way to ruin your engine. I recommend you buy a Superdamper or a stock pulley.
There's a reason why the stock pulley is heavy.
Old Oct 27, 2021 | 07:08 PM
Brandon Fluharty
ok while yes that’s funny and I agree with replacing it with a dampener I’m still trying to source the cause of my front main seal leak
Old Oct 28, 2021 | 06:50 AM
mrbean's Avatar
mrbean
Seals sometimes just leak. I wouldn't worry too much about why it's leaking, unless the new one starts leaking soon after installing it.
Old Oct 28, 2021 | 06:50 PM
Nicefeet's Avatar
Nicefeet
I'm not trying to be funny, it's no longer a dampener, it's cheap drive pulley made out of aluminum on a press fit crank snout. I bet the sealing surface has a defect from being pressed on or the crank harmonics are so bad they're beating up the seal. I've never been a fan of Alta products, some things they get right, others are just junk to steal your money
dmf2020
Sep 6, 2020 12:36 PM
bansasn
17
Feb 17, 2016 10:17 AM
boydie
Jan 20, 2016 01:22 PM
THE ITCH
Dec 18, 2005 03:27 PM
