R50/53 Thoughts and specs on these injectors - 2002 R53 stock?
Summary:
2002 R53 225k? mi, I’m third? Owner
All pics - https://photos.google.com/share/AF1Q...VHNUtRc056WlRB
1) Are these injectors stock?
2) What PSI/Bar should they be at?
3) Any other thoughts?
1 -Injectors:
Siemens Deka
1054
1521390
2- What pressure/flow?
When I was researching these, saw one place that said R50 is 3bar and R53 3.5bar. What should my R53 have
What should be the flow on an OEM injector?
3-
See the mangled O-ring on Injector 1?
The FI cleaning Co said they could do what ever PSI/Bar I tell them and are willing to do a pre-cleaning assessment/test so I know what the car has been happening with.
More on this situation:
Pulled these injectors from my 2002 R53 mini (3rd ? owner 225k mi) and sending them to these folks to solve a DTC code (I forget now which one just know that FI was the next step, lean code?...forget because it was last year I rant this car last) that wasn’t solved with the usual Catalytic replacement https://highperformanceinjectors.com...eaning-process who were suggested in this thread https://www.northamericanmotoring.co...e-related.html
I am not sure what the POs did. When I did the Timing chain chasing an oil leak the prior one was off a tooth so I’m not expecting anything in here to be stock https://www.northamericanmotoring.co...oem-marks.html
Thanks in advance for your help.
Summary:
1 -Injectors:
Siemens Deka
1054
1521390
3-
Yes oem but idk what your looking fir but your looking far too in depth into the injectors if your thinking they're your issue... hook up a data logger like inpa and see exactly what's going on with the engine and sensors and everything. Don't just guess because you'll be guessing fir ever or atleast until your broke and totally frustrated.
you want some guaranteed good, stock injectors? You can have mine , shoot me an offer..I'm upping to 440s anyways.
the stockers are still on my engine now but can remove on the drop of a dime.
don't be scared to use the search button in the top right either, there's endless information on here all peeps gotta do is hit that search button..not saying yiu but I see the same questions constantly when they could be answered with a simple search on here or even google.
https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/343641-inpa.html
I am going down the INPA road. received my cable and am awaiting on user "shrevemini" to feel better to do the remote install..... looking forward to seeing all that INPA can tell me.
M7Tuning
Jun 4, 2013 10:00 AM
Drivetrain What Injectors are these on my R53
lugnuttz
Jan 15, 2011 07:57 AM
