R50/53 2 Quick questions
Old Aug 18, 2021 | 04:49 PM
ChiefM's Avatar
ChiefM
2 Quick questions
My R50 is my first Mini and I have no idea what normal operation is.
When I turn the key without starting the engine the power steering pump is loud. I thought it was the blower fan. Is this normal? Should I be concerned? The steering works fine and you can't hear it when the engine is running.
I am dropping the bottom frame to put in control arm bushings and ball joints. I have a new exhaust manifold with a cat coming. Do I drop the old exhaust out the bottom? Would it be easier to install with the bottom frame out?
Thanks in advance!!
Old Aug 18, 2021 | 05:50 PM
Da_Ghost's Avatar
Da_Ghost
The power steering pump can be loud while still working. Even a new one can be a little whinny.
You can install the manifold without taking the subframe out. Both the OBX and the RMW were fitted from under on mine, but it's easier on a lift since you can play a bit more with the angles.
Old Aug 19, 2021 | 08:57 AM
cooper48's Avatar
cooper48
Just about everything is easier with the subframe removed.
Old Aug 19, 2021 | 12:31 PM
ChiefM's Avatar
ChiefM
Thanks!
I have an exhaust manifold with cat coming and just wondering if it would be better to leave the frame down till it comes in and I can install it and then reinstall the frame. It's just me so the easier the better.
cnusbtkg
Sep 16, 2019 07:16 PM
Nitrocrusher
Dec 22, 2014 12:03 PM
Fir3Chi3f
Jan 12, 2014 05:04 PM
Jim_Chilenski
Jun 5, 2012 07:32 AM
