R50/53 Is my clutch slave cylinder fully extending?
Hi, new to the forums, just got a manual r53 from an auction and hoping to keep it for some time!
That said, it needs some work, particularly with (I think) the clutch slave cylinder. I'm having problems getting in gear when the engine is running, while the shifter moves fine when it's off. The initial thought is that there is an issue with the clutch master or slave cylinder. (Originally thought it was a pilot bearing but learned these don't have one?) I took a couple images of what the slave looks like when pressed/not pressed:
Pressed:
https://i.imgur.com/T4FopdJ.jpg
Unpressed:
https://i.imgur.com/HuAjeFD.jpg
I haven't worked on these before so I'm unsure if this seems to be fully extended, or if it seems to be the reason for my lack of shifting.
Pressed:
Unpressed:
If you need a tool to compress your slave , I made one for me n my buddy when we had to do our slaves..just cover shipping if you need it.. I went through a headache replacing my slave but figured it out and easiest way to get it so if you need some help , feel free to pm me and I can give you my # for if you need any help..
also pull up your shifter boot. Put the shifter into reverse and 6th and if you see that little bushing around the base of the shifter move , that too could be casuing hard notchy shifts..thats my issue rite now..that bushing needs to be firm and the ear tabs can Crack off and it causes it to lift alittle when changing gears and it causes bs symptoms...
maybe my post might have some help
https://www.northamericanmotoring.com/forums/r50-r53-hatch-talk-2002-2006/357396-help-why-won-t-my-slave-bleeeeeeeeeed.html
Boe6Eod7Nty
May 30, 2022 03:48 PM
mdurando
Sep 25, 2016 09:26 PM
edprok
Jun 8, 2016 10:50 AM
dwm
Nov 21, 2006 12:07 AM
