R50/53 Scangauge2 paper insert with specs
Hi hoping someone can help me out:
bought a scangauge2 from WMW and lately the vendor no longer adds a paper insert with the vehicle specs pre-programmed. I called Ways shop said it should have come with one so she opened a new box and confirmed “no paperwork”.
I’m guessing it has things like vehicle weight, tank size, final drive ratios, tire size, etc.
does anyone out there have this and willing to post up a pic of the insert that includes the information?
PS: I’ve got an R53 if that matters
TIA
-MD
TIA
-MD
The Manual I’ve got and customizing w/ x-gauge seems straightforward.
but the unit is supposedly programmed for the 1st gen Cooper. until recently (according to WMW staff) it would’ve come with a spec sheet that tells the user what variables were added.
I’m looking for that spec sheet (pamphlet/ insert)
I took the scanguage out of my diesel truck and plugged it into my R53. Works without issue. I typically monitor OBDII functions like IA (intake ambient temp), water temp etc.
I'm curious what functions might have been pre-programmed into it for a specific car. In fact, I didn't even know they did that.
I'm guessing functions like engine load, gear selection etc. ?
mind you I’ve got an r53 and neither his or scangauge specifically call out the 1gen mini.
Way Motor Works (from the website)
WMW Exclusive: All our Scangauge II come preprogrammed for 2007+ MINI functions
EOP- Engine Oil Pressure (ONLY on N18 engine and F56 MINIs)
TFT- Transmission Fluid Temp (Auto Trans ONLY)
EOT- Engine Oil Temperature
A/F- Air Fuel Ratio
FRP- Fuel Rail Pressure (PSI)
ENG- Engine Temperature
A/F- Air Fuel Ratio
Interior/Exterior R53 - Where to secure weapon???
PoppaDLo
Mar 14, 2012 03:46 PM
Robin Casady
Tires, Wheels, & Brakes
Aug 11, 2009 07:22 PM
