R50/53 05 R53 front main seal leak
Old Jun 11, 2021 | 04:28 PM
gforce1108's Avatar
gforce1108
My buddy’s mini came back with an oil leak. Back side of car covered in oil. I found the front main seal leaking - easy enough to replace. What I found odd was that the seal was out about 1/8” on the bottom. The prior owner had just had some oil leaks fixed - unsure what. I’ve fixed a number of others (mostly sensor orings). High crankcase pressure doesn’t seem to be a common issue on these from what I’ve seen.
I’ll check the PCV - any known issues associated with this?
Cleaned leaking seal
Before - seal sticking out.
Old Jun 12, 2021 | 05:05 PM
cooper48's Avatar
cooper48
Sounds as if the seal wasn't installed properly or it's the wrong seal. No way it should back out.
Old Jun 12, 2021 | 05:14 PM
gforce1108's Avatar
gforce1108
I am leaning that way. My main concern is is it has high crankcase pressure pushing out the seal. VW 2.0 TSIs have a crappy pcv system and weak bonded rear main seals. Blows them right out!
He is going to run it hard and see what happens 😀
yyj3869
May 7, 2019 06:36 PM
Stuti Tandon
Feb 2, 2017 01:07 PM
traildog
Oct 28, 2014 03:26 AM
solomio
Aug 22, 2014 06:24 AM
choupette
Oct 24, 2012 10:05 AM
