R50/53 Permanent starting problem
Old Apr 20, 2021 | 04:55 PM
jwbr71's Avatar
jwbr71
Hi. My 2006 R50 with automatic steptronic transmission have a weird starting problem. When I put the key at first position, all dash lights and indicators seems to be ok, but when move the key to the second position, appear a clicking noise (4 or 5 fast click relay noise) at two points: fuse box located at drivers kick panel, and engine fuse box. When this happen, the starter works, but the car wont start. Each time I remove and reconnect the battery terminal with the key at on position, the clicking noise start to dissapear with less number of clicks, so when disconect the battery 4 or 5 times, the car start without any problems. Then, if I turn off the engine, and try to start again inmediately, it will start, but if I left the engine off some minutes, the problem come back again. Any ideas? I will make a video of the problem, to see if anyone knows whats wrong with the car. Thanks.
Old Apr 20, 2021 | 08:26 PM
Minifenrir's Avatar
Minifenrir
What is your battery voltage? Sounds like a weak battery or maybe a loose connection
Old Apr 20, 2021 | 08:39 PM
jwbr71's Avatar
jwbr71
Hi. I just replaced the battery, so it is brand new.
Old Apr 21, 2021 | 11:43 AM
geauxturbo's Avatar
geauxturbo
Agree with Minifenrir. I would start by checking (remove and clean) the ground cables, your battery terminals could be bad as well.
Clicking is usually a solenoid or relay. So, you could have a bad relay to the starter. But, it sounds like the power is getting cut to the relay and that's why its making a clicking noise.
And, I'd also have the starter checked.
nickVC
May 28, 2018 08:30 PM
amarr003
Aug 7, 2014 10:44 AM
harhoosh
Jul 30, 2007 10:43 PM
MyMiniME
Nov 26, 2006 04:18 PM
Brihyanna
Jul 18, 2006 12:31 AM
