R50/53 Pros and cons of Supercharger pulley vs supercharger/ crank pulley combo
Old Jun 19, 2021 | 06:18 AM
  #26
HeyDadCELIsOn's Avatar
HeyDadCELIsOn
Running both ATI and 17% for 100K miles
Originally Posted by RB-MINI
A 2% ATI is 2% bigger than a stock MINI pulley. What I posted is the “stock” size ATI is supposed to be .8% larger than a stock MINI pulley so that should be factored into a pulley size decision depending on the max gas octane available in your area, or if you’re already close to pinging.
The smaller the pulley, the greater the stress and wear on the belt so I think a 15% or 17% with a 2% ATI should put less strain on a belt than a 17% or 19% alone. Others say it doesn’t really matter if you change the belt often.
I’ve read about the concerns regarding alternator and A/C speeds, but unless I’m missing something, I don’t see how the small differences in RPM’s from the chart above could really cause an issue. If you’re really concerned there are pulleys available to adjust for a larger crank pulley, at least for the alternator.
About to turn 200,000 miles on my 04 MCS. Running both 17% pulley and ATI damper for last 100K (Way Motor Works installed). Serviced the supercharger a couple times, couple belt swaps-- no issues at all, and Hercules performs as well as day installed. Also ECU tune from Way. Worth the investment.
epanarese
Oct 6, 2009 08:57 AM
Peter W.
Mar 6, 2007 03:20 PM
SORMINI
May 25, 2006 12:10 PM
sea_to_sky
Nov 8, 2005 02:32 PM
jonnieoh
Jun 27, 2005 07:00 AM
