R50/53 Sludge in coolant keeps returning
Old Aug 5, 2020 | 05:31 AM
peerware's Avatar
peerware
Hi, probably yet another topic on oil and coolant sludge but I can't find an answer to my issue.
2 weeks the r53 started to smell strange and smoke was coming from under the hood. There was a milky mix steaming out of the coolant reservoir.
After searching around, I found (on this forum) that there could be an issue with the heater exchange. So on good luck I just ordered a new one (including gaskets) and started to dismantle the part and cleaning up the engine.
The old part was blocked and dirty so that could be a sign that it is the heat exchanger. I flushed the radiator with a hose, tried to flush as much I could. Installed the new parts, added the coolant with a 'sludge cleaner'.
Run the engine for 15 minutes, flushed the coolant again and added new coolant again.
Now comes the issue: Although the temperature keeps ok, there is no sludge in the oil and there is not to much pressure or something, it keeps on creating a very small layer of sludge on top of the coolant in the coolant reservoir.
I can get it out but after a few miles there is a small layer again. (i have drive it now for a few days)
Should I fear the head gasket (leaking between oil and coolant). Or could this be residue sludge in the coolant hoses/radiateur, interior heater?
I'm curious on your thoughts.
Although it is a 2004 car with 240000 miles on it, we like the car, it looks perfect and we want to keep driving it
Old Aug 6, 2020 | 08:04 AM
BernieCoop's Avatar
BernieCoop
How long has it been since swapping out the heat exchange? It's probably is just a little residual sludge working its way out. If it's still doing it after another 1000 miles, I would look further into it. Just keep up with your fluids for the time being
Old Aug 6, 2020 | 08:10 AM
peerware's Avatar
peerware
I think I only drove it 50 miles now in total after the exchange. I will keep an eye on the fluid.
Michaelh57
R60/R61 Stock Problems/Issues
Apr 27, 2020 04:18 PM
danthemanohhyea
Jul 23, 2012 11:03 AM
jerjer
Oct 20, 2008 02:48 PM
gizzer777
Nov 29, 2006 11:10 AM
RECOOP
Jul 19, 2004 03:32 PM
