R50/53 Adventures with “Rusty”
Old Aug 13, 2020 | 10:56 AM
  #26
Chris In Milwaukee's Avatar
Chris In Milwaukee
Originally Posted by JerBear
Dam good job on the rust repair man! I would suggest you take a good look at the valve cover gasket, harmonic balancer, and serpentine belt. I have a 2003 R50 and they all needed attention. Hard to tell in the pics you posted but you may have the same issues. My valve cover gasket was leaking on the side closest to the firewall. Made a mess on the back of the motor. The oil on the back of the motor could also be from someone changing the oil filter and not cleaning up after themselves...
Also, since you mentioned it , you definitely should buy another for yourself!
Thanks for the tips! I don't know how much more effort I'll put into this particular car since it's going to be driven by a 16yo and may end up banged up more than anything. I'll guess we'll see what really happens to it!
It did have some oil on the back as you described, so could be any of those things. If it keeps creeping, I'll look into the updates. At least valve cover gasket is pretty simple looking. I have an oil pan gasket, too, but I haven't yet been motivated to install it. I went with the crank sensor gasket first and hope for good results.
If I were to buy another, maybe an R53 would be in order! I'd definitely look for one whose life has been spent outside of Wisconsin!
Old Aug 15, 2020 | 10:58 AM
  #27
Chris In Milwaukee
Aaaand a check engine light... O2 sensors. Only took four hours to replace them.
Had to disassemble the cat from the exhaust so I could swivel it over enough to remove the aft sensor. Otherwise the wire is nearly touching the heat shield. Not getting it out without doing that.
Now it’s done. This fix was... challenging. Sure would have been easier to do this with the front subframe off. The last one finally threw up the white flag with a sensor socket, 1/2”-to-3/8” adapter, universal joint, 4x 1/2” extensions (one of them a wobbler) and an impact gun. Take that sensor!
Old Aug 15, 2020 | 01:18 PM
  #28
Chris In Milwaukee
Last but not least: rally stripes. It was necessary. And my daughter’s tag line.
Old Aug 15, 2020 | 01:23 PM
  #29
colinmini's Avatar
colinmini
Bonnet stripes tie the front, roof and rear all together! Nice job!
Old Aug 16, 2020 | 07:25 AM
  #30
user 7389739's Avatar
user 7389739
+1. Don't even bother looking at them, just replace. Especially the balancer - trash right out of the factory. Get an ATI if you can swing it.
Excellent, well done project! Are you leaving the LR corner matte black because "NOT NOR MAL" or is a quick mask and rattle can spray job in the offing?
Old Aug 16, 2020 | 07:52 AM
  #31
Chris In Milwaukee
thanks! The RR corner is matte black, too. . When I did the rust “repair”, I used spray bed liner to finish the area. You know, like when you use spray texture on a drywall project because you’re a suboptimal drywall guy. Same thing here.
Old Aug 17, 2020 | 07:37 AM
  #32
user 7389739
Most excellent - golf gallery claps all the way around.
Phobic
Classic Mini Talk
15
Apr 26, 2016 04:31 PM
SAM.MAY
12
Jan 29, 2010 06:58 AM
Aussie mini
Classic Mini Talk
37
Dec 25, 2007 04:24 PM
mr. jim
Jul 1, 2007 07:40 AM
OctaneGuy
Detailing 101
31
Jan 18, 2007 04:31 PM
