R50/53 Project "rice"
#76
Hey man, LOVE this car! Looks dam good!
I had a couple questions though.
Do you have a link for the front lip you used? I know you said it was an eBay universal but if you have a link that'd be sweet.
Also, do your tires rub and is your suspension stock? You list your tire/wheel setup as "15x8 et25 with 5mm spacers and 205/55r15 street tires". I have 15x8 et20, no spacers, and 205/60-15 tires, they rub pretty bad on hard corners or big bumps. The rear is worse than the front. I'm running Bilsteins with stock springs.
https://www.ebay.com/itm/FOR-MINI-CO...AAAOSwP4ZZwGA7
#77
Thanks for the link! I was on eBay for quite awhile yesterday after reading through your thread. I couldn't find one quite like you have but it looks like it was made for it so I wanted to get the same one. Your tires not rubbing is interesting. I wonder if going from a 60 series tire to a 55 is enough? I'm also not sure I entirely understand wheel fitment as far as offsets are concerned. They way I understand it (and I'm probably wrong ) is my et20 should be the same as your et25 with a 5mm spacer.
Anyway, I love what your doing with your car, keep the posts coming! I'm sure I'm not the only one enjoying the read. Us noobs get inspiration for our builds from people like you that take the time to share what you did and how you did it.
#79
#80
I love pictures! So yes please, if its not too much of a pita. My front tires barely rub and very rarely at that. I'm hoping the I.E. camber plates I just bought will fix that. The rears are worse. Looking at how far down the sidewall they rub its obvious that they are tucking up into the fender but still barely scraping. I'm not crazy about adding too much more camber to the rear but I might try a set of control arms and see if I can get it to tuck in just enough to clear. I plan to buy a bigger rear sway bar too (hopefully very soon) so that might reduce some of the rubbing from cornering too (less body roll). I'd honestly rather just sell this wheel/tire setup and go with a 195-205/50-15 on a 15x6.5 rim. I have an R50 so any weight advantage I can get is a plus.
#81
I would go as wide as you can on the rim btw . I feel these cars need as much tire to pavement contact as possible .
and if you did camber the wheels it would for sure help tuck them. a recamber on my buddies r56 was enough on stock stuff to stop his setup from rubbing as he's running a 215 wide and drop springs.
#82
OK thanks for the info. A set of control arms would be cheaper than a whole new wheel/tire setup and I do like the way these look, although the set I have in mind would shave another 6.5 lbs of unsprung weight off each corner. I think I'll try control arms and a bigger RSB and go from there. I can always drop the tire size to what your running too when this set wears out. Thanks for the response man it's a huge help.
And sorry I didn't mean to hijack your thread!
#83
#84
Got everything painted and cleaned up under the hood I wanted too and it all turned out nice, imo I like the contrast that the aluminum mounts are now black and hide so the intercooler and intake stand out more and then i did the support bars all red as well as the bushing canister because DUH , red means performance (and its my favorite color).
also I snapped a few pics of the fitment on my tires to better show how they sit. I think these ebay tires design helps . They even have a ridge/lip thing to prevent you from curb rashing your rims and then the tread is set kinda back almost staggered or something.
I also might not be getting rub because I do have the sportplus suspension on the preface lift which people actually complained it was too stiff(geez) and I have the front and rear support bars which may help.
BUT DO NOT GET THESE TIRES. Look nice, ride comfortably but ARE GARRRRRBAGE. The treads worn down fast as F as you see my front are almost done and ive put like 7 months on them maybe and like 25k miles MAX. They also don't provide even decent traction , just suck. Ive learned my lesson about cheap tires, THATS ONE THING you CANNOT skimp on. They make a huge difference in performance , just tires alone !
#86
Hehe snagged both these for 35$ only on sale so im gonna need a torque wrench on hand so just bought a cheapo that's actually very nice. Tested it with a snap-on one and it was same torque specs as it so im sure its all calibrated correctly and the little hat light , heck YA its bright and no more having to aim light where I need. It will always be lit anywhere I'm glancing around now..CMON HEAD ! I can't wait to get it.
#91
#93
4 sure ! Almost anytime im out working on the car shes helping.
I also got my porting tool, I will get a porting bit from harbor freight soon enough. I grabbed this cheapo dremel because I had to return something anyways plus it was 20% off and theres nothing else of use in that store for me so I figured to spend it on at target , ugh , hate target . Lol
#94
#95
#96
Returned the torque wrench and dremmel for what's pictured below . THE GUY AT HARBOR FREIGHT GAVE ME THE DIGITAL TORQUE BOX FOR FREE FOR STANDING UP FOR HIM TO A JERK CUSTOMER, LOL long story but seriously.
the porting tool i ordered seems much more heavy duty and fits larger size shanks, i also bought porting bits, lol all he rang up .lol coooooool . Glad theres still cool people left out there.
that 40$ i just saved will be re invested into this head job im planning on.
#97
Oh that tool you ordered looks mad sweet! I like the chuck on it too! And for porting (or polishing) harbor freight also sells a sandpaper roll kit for small rotary tools. That's what I use for polishing ports. They work great. I will say I have never polished an aluminum head, only iron, so maybe I shouldn't comment on the subject lol.
#98
Low-speed setting on my fan went out so im sure its the resistor so I strait wired it with a switch n stuff to run on high-speed until the replacement arrives.
my map sensor also went bad and what a pita it was diagnosing and figuring it out but lol I'm glad it did because now that they have been cleaned I swear to GOD it makes the car pull so much harder, either that or tightening my belt more helped bit either way man,damn. Rolling at 5mph and full gunning it within a few seconds i have to let off as im hitting 80-90 and still pulling hard . It sqeals them going into 2nd now harder than it ever has and shifting into 3rd it bucks the car forward n back , lol its fricken awesome !
I HIGHLY suggest cleaning both map sensors guys. BOTH mine were pretty dirty,i used mafs cleaner..
from what I've been taught and have read you actually don't want a full polish but actually like a 100 grit. So a little rough not perfectly smooth on the intake side.. exhaust im pretty sure should be polished. Thats what i did on my tbird back when and i was happy with the results after.
#100
But all that to say, if done right, there are some huge gains to be made with porting.
