R50/53 zero compression cyls 1 and 4
Old Feb 21, 2020 | 12:23 PM
hoodmeister's Avatar
hoodmeister
zero compression cyls 1 and 4 SOLVED
R53, 2002, 245K, burns oil by the gallon which I know to be rings, and sudden power loss. Barely limped home. Did compression test and got 125ish psi on 2 and 3, but zero on 1 and 4. Cam sprocket jumped the chain? I can't think of any other reason to have two cylinders at zero and two with some compression. Unless valves simultaneously failed, or simultaneous holed pistons! Dang, and I replaced the head 25K ago. (should have done the oil rings then). I'll pull the valve cover. Any leads on R53 short blocks? Rebuilt engines? I'm in the mid Atlantic region.
thanks!
BURNT EXHAUST VALVES ON BOTH CYLINDERS, HAPPENED AT THE SAME TIME!
Old Feb 23, 2020 | 01:10 PM
hoodmeister
I had no choice but to pull the head. I was pretty surprised to find a burnt valve in both Cyl 1 and 4. I'm thinking a chunk of one valve caused the damage to the other. My oil rings are shot so I have a lot of carbon on the exhaust valves. I suspect that may have helped fail the valves as it would cause uneven heating.
Old Feb 23, 2020 | 04:31 PM
ssoliman's Avatar
ssoliman
What’s the action plan from here?
Old Feb 24, 2020 | 04:45 AM
hoodmeister
Good question. I know the oil rings are shot, so I'm considering re-ringing the pistons while the block is still in place. Then replace all the exhaust valves as my head only has about 55K on it and the cam lobes look really good. No pitting like my first 220K old head. The car had 245K on it, so the bottom end is probably on it's way out, but then again, 300K and beyond happens all the time. Or I try to find a complete engine on eBay....or maybe locally. I messaged ModMini and he recommends a used engine, so there's that. I love the car. For a 2002, it looks brand new.
Old Feb 24, 2020 | 06:53 PM
ssoliman's Avatar
ssoliman
Solid. I like the idea of finding a low mileage engine
Old Feb 25, 2020 | 04:22 AM
hoodmeister
Lots of 100K ish engines out there on LKQ in my area. They seem to be everywhere in the US, so a good place to start. At least you know the mileage and there's a guarantee. '02-'06 SC engines are interchangable.
Manny_cooper
17
Nov 1, 2024 07:46 PM
GsxR1000
Dec 8, 2018 06:34 PM
atheos
Jan 13, 2018 01:36 PM
Domiracer
Apr 2, 2014 06:39 PM
herbie hind
Nov 6, 2006 02:19 PM
