R50/53 busted crankshaft damper
Old Jan 24, 2020 | 10:39 AM
speedman's Avatar
speedman
I had the rubber centered crankshaft damper come apart on the 05 MCS. I ordered a new Super Damper and when I was installing it the damper went on completely by hand without a press fit. This is not good so I am looking at ways to fit the Super Damper to the crank. I think one way is to pin it using a 8mm removable dowel pin. Is there any other suggested ways to repair this short of removing the crank?
Old Jan 24, 2020 | 11:30 AM
A383Wing's Avatar
A383Wing
sounds like the crank snout is worn down, not good.....or.....maybe the super duper damper is machined wrong on the inside where it rides on the crank.
you only have two choices here....try another damper, or replace the crank
I would not trust a dowel pin in this instance
Bryan
Old Jan 24, 2020 | 12:58 PM
cooper48's Avatar
cooper48
Sounds like you don't have the correct crank pulley. Check with the manufacturer.
Old Jan 24, 2020 | 01:37 PM
Black Forest's Avatar
Black Forest
Compare the ID (inner diameter) from the original to the replacement. You will need a caliper to do so. Past that see how the original fits. If it just slides on you may have an issue.
Old Jan 24, 2020 | 11:30 PM
Dirtsquirt's Avatar
Dirtsquirt
You can use a retaining compound, loctite 660 is made specifically for shaft repair
PariDot
Aug 21, 2018 11:22 AM
Professor
Jan 1, 2013 08:08 AM
sampsonm
Aug 21, 2007 05:41 AM
Electrc109
Sep 19, 2003 04:46 PM
