R50/53 Center Arm Rest Cover Question
Has anyone had good luck with the replacement center arm rest covers that are $15-$20 on eBay and come from overseas?
I figured for that price, I just might take a chance and get one for my '06 R52 because mine won't stay closed
Thoughts and input appreciated
Bryan
Bryan
Oh, don't worry, those won't stay closed either. I actually used one of those to repair my original equipment center armrest. The bottom (with the pieces that slide in the slots) was broken, so I carefully removed it and did the same with the Chinesium replacement and then used the Chinese one on the BMW pad. It does not like to stay in place. Ultimately, it was a defective design and there isn't much that can be done about it. The Chinese one was manufactured using a mold taken from good original parts, but is made of inferior materials. The original is PA6 Nylon or maybe polycarbonate with fiberglass reinforcement while the Chinese knock off is just cheap ABS plastic. Plus, the Chinese one has terrible quality upholstery and foam that in no way matches the interior.
Concur with the sentiment the eBay replacements are cheaper in both cost and quality. I did the same as above and swapped the OEM pad to the new eBay slide mechanism. Mine wouldn't stay shut until I epoxied 4 sets of neodinum magnets onto the closure. The more you add the better the mechanism will hold.
KT Kelly
10-04-2018 07:12 PM
