R50/53 Oil pan gasket leaking after install?
Old Sep 1, 2019 | 05:22 PM
r53-06m6's Avatar
r53-06m6
I recently replaced my oil pan because the last one had an oil plug that could not be removed. I made sure that both surfaces were super cleaned and lined up everything correctly along with using the correct torque spec.
I took a look at the underside of the car and noticed that oil is slowly oozing from what appears to be coming from the rear of the oil pan (side facing the back of the car). It doesn't leave any marks on the ground so I am not eager to drop the pan until I need to get back down there again.
I am pretty good at finding leaks but was wondering if there is anything back there that gives the appearance of a leak at that location??
I will clean up and add dye if necessary but just don't have that sort of time right now.
Thanks for any info as to what that leak might be if it is not the gasket.
Thanks.
Old Sep 1, 2019 | 08:18 PM
veedubpat's Avatar
veedubpat
The oil cooler is up there, just above the power steering cooling fan. That's a common item to leak.
Old Feb 24, 2025 | 12:14 PM
Jackcooper's Avatar
Jackcooper
I, have the same problem on my 2005 R52. Have you found the issue?
Thanks.
I have the same issue! However I noticed that if the car if park flat. There is not leaks, but if I put it up on the ramps with the incline. I’ll see The tiny zipping.
Old Feb 24, 2025 | 01:14 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Replaced my old leaking oil pan gasket and discovered a tiny leak coming from the timing chain cover as well.
As stated above: Oil filter and cooler leaks are common and are/is located just above where you mention you now see drips.
Old Feb 24, 2025 | 02:18 PM
ssoliman's Avatar
ssoliman
the oil filter housing gasket or in basically the same spot, check the pressure / temp sensor that goes into the back of the oil filter housing. Mine is leaking.
romero.riche
Nov 24, 2017 09:59 AM
adriromas
Apr 22, 2015 11:36 PM
jaldeborgh@gmail.com
May 16, 2014 10:51 AM
KrautHammer
Apr 16, 2013 04:48 PM
jc8899311
Jun 27, 2009 07:31 AM
