R50/53 Steering column "clunk"
Old Jun 10, 2019 | 04:57 PM
Island_Moose's Avatar
Island_Moose
Sitting in the car, idling or driving straight. If I move the steering wheel left and right slightly I can feel a solid knock coming from somewhere between the wheel and the rack. There's no looseness, it's like the way my knee cracks everytime I stand up. Any ideas where I should look first?
Old Jun 10, 2019 | 05:30 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
It could be caused by worn outer CV joint(s). I had this symptom and I suspected the cause and I was spot on. Replaced both axles with $150 communist made set and the clicking and subtle binding are gone.
Old Jun 10, 2019 | 05:31 PM
JAB 67's Avatar
JAB 67
What about the universal joint that connects the steering column to the steering rack?
Old Jun 10, 2019 | 05:36 PM
Blue R50's Avatar
Blue R50
I would try to move the whole column from side to side. Mine has a little looseness left to right. The other thing to check would be the U joint where it attaches to the rack from the column. If it has ever been in service mode, this may have been inadequately tightened. It could also be a bad tie rod end. That is fairly easy to test for by jacking the car up and trying to move the wheel left and right. There should be no play at all, only the resistance to movement from the rack to the pinion, which may let you move it slowly and with great effort. Yet another issue can be bad strut mounts. Look at the top of the strut towers and see if the strut mounts are torn. It will be visually obvious if they are. Lastly I would look at the lower control arms and their bushings and ball joints. I would check all of it thoroughly and figure out where it is coming from.
Old Jun 11, 2019 | 03:25 PM
Island_Moose
Thanks all,
I'm going to start with the u-joint on the column, as part of my rebuild has been to replace the front suspension entirely, and reinforce the strut towers.
Old Jun 11, 2019 | 03:28 PM
pnwR53S's Avatar
pnwR53S
I will not replace the u-joint unless I prove it defective. If it is so loose the car will wander at freeway speed.
It is easy enough to test. With engine not running so you have no power assist, turn the steering back and forth and if you have no click or play, it is good. It is that simple.
Old Jun 11, 2019 | 04:50 PM
A383Wing's Avatar
A383Wing
I had the same "clunk" noise in my wife's car a few years ago.....turned out to be a bad outer tie rod end......check the simple stuff first
Bryan
Old Jun 11, 2019 | 07:44 PM
gumbedamit's Avatar
gumbedamit
Inner Ball Joint
Old Jun 12, 2019 | 01:11 PM
Inner or outer ball joints/tie rod, https://www.northamericanmotoring.co...ll-joints.html
if it's still there and the steering wheel is hard to turn that it can be the steering wheel shaft.
https://www.northamericanmotoring.co...-any-tips.html
Old Jun 12, 2019 | 08:25 PM
Tgriffithjr's Avatar
Tgriffithjr
Raise the front of the vehicle. Put your hands on each tire at the 3 and 9 o’clock positions. Push the tire in and out. If there’s movement it’s the tie rods.
astroBlackMetallic_Mini
20
Dec 17, 2015 07:04 AM
scf
Mar 19, 2015 12:02 PM
Toads MINI
R58 :: Coupé Talk (2012+)
31
Apr 29, 2013 06:49 PM
mikewitdaspike
Classic Mini Talk
Feb 23, 2013 04:32 AM
mini626
Sep 13, 2006 09:50 AM
