I made a tool something similar to this to do the job (I am a die maker with access to all kinds of machinery). I have always been a little wary of using the sawzall method to cut them out, in case you cut too far thru and into the bushing housing. Did you have any problems getting the inner ball joint free from the LCA? My drivers side was a real PITA.
One came off with a bit of prying, the other I had to cut off with a dremel. I still have an outer ball joint attached to my LCA, I have to find someone with a press...it’s fused.
